Newer Versions won't d/l correctly
    I haven't used my DVD fab program for a few months, as I still have version 8.2.1.3. I am trying to obtain version 8.2.2.0 and it's no where to be found. When I click on the site that POTTI recommends, it goes directly to a page for a free trial version of 8.2.2.2. How do I get 8.2.2.0? Also, I tried to d/l the movie Brave from my 8.2.1.3 version and it skipped the very first part of the movie. I've done it twice and it still won't copy correctly. Will version 8.2.2.2 correct this? In trying to d/l the newest version of DVD Fab, just released 11/24/12...it d/ls but a window comes up and states that I have to buy it, try it, or register it. Usually the older versions would just be available without all of this extra stuff. Last question, how am I able to use the newest version and what do I have to do to use it once it's d/ld?
    Thank you,
    Crickkette
    Try this:
      Thanks, but that just takes me back to the same page POTTI posted, for version 8.2.2.2
      Also, I think somehow my registration got lost somewhere. My version of 8.2.1.3 says I am registered to use my DVD program until 2015-Mar-07. Can you find out if this is correct for me, and also how do I obtain my registration number?
        8.2.2.0 has been updated and is no longer supported. You'll have to find a member that still has the installer. And just double click the key that was sent to you to make any version 8 work.
          Thanks for your help! I'm still trying to get a version of Fab that will work to copy BRAVE, without any glitches. Haven't found one, yet. :-(
            Hi Crickkette
            The new version should be able to handle this movie, you should have no problems with registering it also.
            You can also try version 9 found here it will install in a separate folder so you do not have to worry about installing over your version 8
            Hope this helps
            CBR929
