advanced settings
    advanced settings
    In version 9 where are the settings to reset the DMA and also disable the transfer file for apple mp4?
    You said two problems are in our to do list both. Also "Check for DMA automatically", "Add Auto Play handler", "Check for on-the-fly decrypter automatically", "Customize UI" and "Rewind when done playing" of DVD Merge mode are in our missing options list. We are working on this.
