In 9.0.1.6, using Blu-ray Copy and outputting to .iso format, disc is decrypted normally to temp folder, but the iso creation process slows enromously...like 6-8 hours for the creation. Version 8 typically does the iso creation task in 20-30 minutes. When I disable CUDA acceleration on ver.9, and just allow software "conversion", the iso creation rate returns to the 20-30 minute times I get with version 8. I run two nVidia 460 class GPUs in SLI config. Unfortunately, right now, version 9 doesn't work right with them for me. I wonder if others are experiencing this issue?
