DVDFab 8226 v DVDFab 8085
    I have just tried to copy "Prometheus" using v 8226. This failed to recognise the DVD even though 8226 is the latest version. I then tried v 8085 and "Prometheus" copied perfectly. Why is it that the old DVDFab copies OK but the latest version (8226) fails. Surely it should be the other way round?
    Hi belzebu
    Sometimes this happens that is why it's always good to keep older versions, where as the newer one might fail and the older one works like a charm.
    CBR929
