burning problems again
    CPU/GPU burning problems again
    It's me again . I bought a new dvd burner, installed it and started using it. The second try I used it, I started having problems with burning. The device buffer is not detected somehow by imgburn. I also checked my CPU while running both programs, dvdfab 9 and imgburn. Here are some screenshots of my task master. What else can I do?
    ImgBurn Version 2.5.7.0 - Log
    ; Tuesday, 01 January 2013, 14:58:27
    I 14:58:16 ImgBurn Version 2.5.7.0 started!
    I 14:58:16 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7601 : Service Pack 1)
    I 14:58:16 Total Physical Memory: 8,370,724 KB - Available: 4,818,804 KB
    I 14:58:16 Initialising SPTI...
    I 14:58:16 Searching for SCSI / ATAPI devices...
    I 14:58:18 Close Request Acknowledged
    I 14:58:18 Closing Down...
    E 14:58:27 Device->Initialise() Failed!
    E 14:58:27 Device: [0:0:0] HL-DT-ST DVDRAM GE24LU20 OL00 (J (USB)
    E 14:58:27 This drive is currently locked for exclusive access by 'ImgBurn v2.5.7.0 - PID: 7560'.
    E 14:58:27 This drive will not be visible in the program.
    W 14:58:27 No devices detected!
    I 14:58:27 Shutting down SPTI...
    I 14:58:27 ImgBurn closed!
    2013-01-01 15:59:10 ---- ******************** Log session stop 01-Jan 15:59:10.073 PID 1376********************
    2013-01-01 15:51:33 Info Disc ejected by user.
    2013-01-01 15:51:28 Info Writable disc DVD+R inserted. Ready to write
    2013-01-01 15:51:17 Info Parsing disc ...
    2013-01-01 15:51:13 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2013-01-01 15:51:13 Info Drive has IDE-ATAPI physical interface
    2013-01-01 15:51:13 Info New Drive selected : 0:0:0 - HL-DT-ST DVDRAM GE24LU20 OL00 [J] (Usb)
    2013-01-01 15:51:02 Info Current Drive selected : 0:0:0 - HL-DT-ST DVDRAM GE24LU20 OL00 [J] (Usb)
    2013-01-01 15:51:02 Info Using Advanced SPTI interface
    2013-01-01 15:51:02 Info System default language : English (United States)
    2013-01-01 15:51:02 Info User default language : English (United States)
    2013-01-01 15:51:02 Info DLL Version : 4.0.21.489
    2013-01-01 15:51:02 Info DLL : C:\Program Files (x86)\DVDFab 9\vso_hwe.dll
    2013-01-01 15:51:02 Info Version : 9, 0, 1, 8
    2013-01-01 15:51:02 Info ExeName : C:\Program Files (x86)\DVDFab 9\DVDFab.exe
    2013-01-01 15:51:02 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
    2013-01-01 15:51:02 ---- ******************** Log session start 01-Jan 15:51:02.129 PID 1376********************
    Hi dragongirl2010
    Sorry to hear that your still having problems.
    Give this link a read through http://forums.mydigitallife.info/thr...w-to-fix-it%29
    Here is the Microsoft support page http://support.microsoft.com/kb/2529073
    Hope this helps
    CBR929
      If you are still having trouble there is a couple things I would do. 1. if this is a brand new drive you may need to set the region code on it, new drives are usually not set=region Ø. If you're in Cali it would be region 1. And second open ImgBurn by the desktop icon, click on tools along the top then settings at the bottom of the dropdown menu then click the write tab. put a check in the OPC box. This set the optimum laser power for the disc being written. These things might not solve your problem but need to be done in any case.
        Thanks, I'm going to try it.
          are you running Fab & Imgburn with Admin privileges? what kind of blank DVR+R are you using? any possibility another program is open which is restricting your new drive?
          How about a screen shot of your "processes" in task manager.
            What do you mean if I'm running dvdfab and imgburn with admin privileges? I only use Verbatim dvds. I bought this new dvd burner because I thought that was the problem with the other one (being old). I was using an LG Modisc. I bought another LG and I'm still with the same problems. I posted before regarding this issue. The posting was titled "Can't Burn" you can look at it if you want. I try not to run any other programs while I'm running fab and imgburn.
