MKV pass through
    MKV pass through
    I like the MKV pass through but it won't keep the DTS master audio regardless whether the HD audio option is checked or unchecked.
    Is this by design or am I doing something wrong?
    Thanks
    I've just backed up a copy of the dark knight which I converted to mkv - when testing through my C200 it reports DTS-HD Master audio - have you gone into advanced and also if just doing the main movie check what audio is selected
      Have you tryed H264.Autocopy it retains all audio tracks, choose which one you like!
        I don't think that is correct. When I use Ver 9 with DTS audio the ripper gets to around 2% complete and freezes. Version 8 does the complete rip with audiocopy.
          I had to try this for S&G and DTS passed through just fine, the subtitles on the other hand were useless they went by at breakneck speed. Note that I unchecked all other audio streams. MediaInfo below:
          General
          Unique ID : 219007823201540527834459379375463049276 (0xA4C35F5A947B7AFB8A705BD3CEC5A83C)
          Complete name : E:\SHERLOCK HOLMES.Title100.mkv
          Format : Matroska
          Format version : Version 2
          File size : 19.1 GiB
          Duration : 2h 8mn
          Overall bit rate : 21.3 Mbps
          Movie name : SHERLOCK HOLMES.Title100.BlurayRip
          Encoded date : UTC 2013-01-13 00:38:40
          Writing application : DVDFab
          Writing library : libebml v0.7.8 + libmatroska v0.8.1
          Video
          Format : VC-1
          Format profile : Advanced@L3
          Codec ID : V_MS/VFW/FOURCC / WVC1
          Codec ID/Hint : Microsoft
          Duration : 2h 8mn
          Bit rate : 19.4 Mbps
          Width : 1 920 pixels
          Height : 1 080 pixels
          Display aspect ratio : 16:9
          Frame rate mode : Constant
          Frame rate : 23.976 fps
          Chroma subsampling : 4:2:0
          Bit depth : 8 bits
          Scan type : Progressive
          Compression mode : Lossy
          Bits/(Pixel*Frame) : 0.390
          Stream size : 17.4 GiB (91%)
          Default : Yes
          Forced : No
          Audio
          Format : DTS
          Format/Info : Digital Theater Systems
          Mode : 16
          Format settings, Endianness : Big
          Codec ID : A_DTS
          Duration : 2h 8mn
          Bit rate mode : Constant
          Bit rate : 1 509 Kbps
          Channel(s) : 6 channels
          Channel positions : Front: L C R, Side: L R, LFE
          Sampling rate : 48.0 KHz
          Bit depth : 24 bits
          Stream size : 1.35 GiB (7%)
          Default : Yes
          Forced : No
