Locking up
    Locking up
    When running two programs at the same time.
    One of them is backing up and second start scanning the drive but not the one you want, so you press cancel and the program will lock.
    Why they don't have a drive letters in drop down menu so you can select the drive you want to scan
    And so many times on single run program when you press cancel scanning you no longer have access to drives you have to restart the program.
    I personally don't like the new layout for main screen. I don't like the drop down menus for selection Audio and subtitles. All way was easy to use.
