Must I download and install HD Decrypter
    I've noticed on both V8 and V9 it reports that HD Decrypter is free and this will copy your blu-ray or dvd to hard drive.
    I have full copy of DVD Copy, DVD Ripper and Blu-ray Ripper but none of these will copy a blu-ray disc to my hard drive, yet HD Decrypter will.
    But must I download this seperately and if not how do I access it from the main options to then copy then disc to hard drive
    HDdecrypter is the default application after the trial period expires so no you don't have to download and install it separately. Just use Blu-Ray Copy until the trial expires and then you will be using HDdecrypter.
    I don't know for sure if HDdecrypter installs the watermark into the output file.
      thanks - usually just rip but got bd with pcm which can't be converted for mkv file
        Yeah, Fab (and most other converters) don't like PCM... Is there an AC-3 or DTS track that you can use instead?
          yeh, ended up just using DTS instead
