Would someone please expain how I regester from v8 to v9. Is it necessary to download v9 before the regestration process at the member center?
regestration process v8 to v9
Hi je6ffOriginally posted by je6ff View PostWould someone please expain how I regester from v8 to v9. Is it necessary to download v9 before the regestration process at the member center?
My suggestion would be to go to the members area first found here create an account if you have not done so yet, make sure to use the e-mail that you used when you first purchased Fab and password of your choice.
Next download version 9 found here use the e-mail and password you used to create your account in the members area, you should be good to go.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
