Every time I cancel a rip my nvidia GTX-560 Ti always crashes. Why is this happening? Here's the log from the last time it happened.
DVDFab 9.0.2.6 (2013/02/15 10:04:40)
0m 00.01s: Start preload dll...
0m 00.05s: Load dll successful.
0m 00.05s: Start load fabplay dll...
0m 00.10s: Load fabplay dll successful.
0m 00.10s: Windows os type is: 13.
0m 00.10s: Transfer settings successful.
0m 00.23s: GPUAccelerate: 12351
0m 00.23s: CUDA cap: 1
0m 00.23s: Support coreavc decode: 0
0m 00.23s: Graphics info: NVIDIA GeForce GTX 560 Ti : 5.0 : 2.1
0m 00.24s: Qt Translator file load success
0m 00.28s: Start get sys number.
0m 00.28s: Serial number is: 00-02-72-d9-f3-ab:00-1e-e5-e6-9a-77:8c-89-a5-80-b2-11
0m 00.28s: Reg URL link is:
0m 00.28s: Version is: 9026
0m 00.28s: Product is: 2
0m 00.28s: Connect type is: 0
0m 01.08s: Times of connecting error is: 0
0m 01.08s: Parse string is: 21:1394894906
0m 01.08s: Parse string is: 50:1383868439
0m 01.08s: Parse string is: 11:8260762964
0m 01.08s: Parse string is: OV:9026
0m 01.09s: Parse string is: BV:9024
0m 01.09s: Parse string is: S:1641eb07fde13c58af528401b3bf1170
0m 01.28s: End check info.
0m 01.28s: Load config successful.
0m 01.41s: Profile Manager :: Begin Load Profile
0m 01.41s: Init profile data driver sucessful.
0m 01.41s: Init GPU settings sucessful.
0m 01.41s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 01.41s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 07.05s: Profile Manager :: End Load Profile
0m 07.27s: Begin init preview play engine.
0m 07.28s: Init DirectShow engine successful.
0m 07.38s: Init burn engine successful.
0m 07.51s: opening drive H
0m 07.51s: opened i/o
0m 07.52s: got media type 15
0m 07.86s: got max lba 22827423
0m 08.68s: got disc type 20
0m 08.68s: type Blu-ray BDMV
0m 08.68s: volume label MARVELS_THE_AVENGERS
0m 08.73s: internal path H:/BDMV/
0m 08.74s: aacs 1 bd+ 0
0m 09.33s: got bdmv
0m 09.35s: Vendor: PIONEER
0m 09.35s: Product: BD-RW BDR-203
0m 09.35s: Revision: 1.13
0m 09.36s: Vendor specific: 10/09/13 PIONEER
0m 09.36s: AACS version: 1
0m 09.36s: Number of concurrent AGIDs: 1
0m 09.36s: Supports bus encryption: NO
0m 09.36s: Supports binding nonce generation: YES
0m 09.36s: Supports Hybrid discs: NO
0m 09.37s: got agid 0
0m 09.44s: sent host cert chal
0m 09.45s: got drive cert chal
0m 09.45s: BEC 0
0m 09.46s: DRIVE_VENDOR 0x0067
0m 09.51s: got drive key
0m 09.51s: got host key signature
0m 09.51s: verified drive signature
0m 09.51s: verified host signature
0m 09.56s: sent host signature and key point
0m 09.56s: got bus key
0m 09.58s: got agid 0
0m 09.65s: sent host cert chal
0m 09.66s: got drive cert chal
0m 09.66s: BEC 0
0m 09.66s: DRIVE_VENDOR 0x0067
0m 09.71s: got drive key
0m 09.71s: got host key signature
0m 09.72s: verified drive signature
0m 09.72s: verified host signature
0m 09.77s: sent host signature and key point
0m 09.77s: got bus key
0m 10.19s: got volume id
0m 10.19s: got volume id mac
0m 10.19s: volume id is correct
0m 10.20s: got vid
0m 10.32s: blu-ray 8D446AEC8F7214372BC86FA8201DBE48B98488AF
0m 10.77s: cert BEE=0x00 same
0m 12.15s: D F63CD073
0m 12.16s: got vuk
0m 12.39s: got unit key 1
0m 43.75s: Java protection is removed by StealthyClone anti-protection.
0m 43.89s: got discinfo
0m 44.02s: got bdmv
0m 49.87s: stream(27,3,0)/clip(27,3,6) infos are not the same, using clip info to regulate it.
0m 51.31s: got extended bdinfo
0m 51.31s: opened blu-ray
1m 15.67s: Start check Blu-ray Ripper register status.
1m 15.67s: End check Blu-ray Ripper register status: Enable
1m 15.68s: OPList at BD Ripper : (4113.2),(4352.2),(4611.8)
1m 15.68s: Blu-ray ripper check watermark flag: 0
1m 15.68s: ------------------ convert work begin(1/1) ------------------
1m 15.69s: info: create config(bluray2video)
1m 15.69s: info: use profile(mkv.h264.aac)
1m 15.69s: info: bluray playlist(800),angle(0),chapter(2->2),BDAV(no)
1m 15.69s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
1m 15.71s: info: [Video]stream(4113) codec(h264) opcode(compress)
1m 15.72s: info: set output video frame_rate(24000/1001)
1m 15.72s: info: [Audio]stream(4352) codec(dca) opcode(compress) channel(8)
1m 15.72s: info: SubMode(Render) -- Display only forced subpicture(true)
1m 15.72s: info: [Sub]stream(4611) codec(pgssub) opcode(render) language(English)
1m 15.73s: try to use gpu acceleration(1) for video decoding
1m 15.73s: CUDA GPU acceleration for video decoding enabled
1m 15.73s: CUDA GPU acceleration for video encoding enabled
1m 15.73s: info: h264_encode: encode param profile(2) level(41) bitrate(7458)
1m 15.84s: info: connect to sub render filter success.
1m 15.84s: info: processing source(00800.m2ts)
3m 00.05s: ------------------ convert work finished ------------------ 3m 36.65s: Start check Blu-ray Ripper register status.
3m 36.66s: End check Blu-ray Ripper register status: Enable
3m 36.66s: OPList at BD Ripper : (4113.2),(4352.2),(4612.8)
3m 36.66s: Blu-ray ripper check watermark flag: 0
3m 36.67s: ------------------ convert work begin(1/1) ------------------
3m 36.67s: info: create config(bluray2video)
3m 36.67s: info: use profile(mkv.h264.aac)
3m 36.67s: info: bluray playlist(800),angle(0),chapter(3->3),BDAV(no)
3m 36.67s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
3m 36.69s: info: [Video]stream(4113) codec(h264) opcode(compress)
3m 36.69s: info: set output video frame_rate(24000/1001)
3m 36.70s: info: [Audio]stream(4352) codec(dca) opcode(compress) channel(8)
3m 36.70s: info: SubMode(Render) -- Display only forced subpicture(true)
3m 36.70s: info: [Sub]stream(4612) codec(pgssub) opcode(render) language(English)
3m 36.70s: try to use gpu acceleration(1) for video decoding
3m 36.70s: CUDA GPU acceleration for video decoding enabled
3m 36.71s: CUDA GPU acceleration for video encoding enabled
3m 36.71s: info: h264_encode: encode param profile(2) level(41) bitrate(7458)
3m 36.80s: info: connect to sub render filter success.
3m 36.81s: info: processing source(00800.m2ts)
4m 05.67s: ------------------ all convert work cancelled -------------------
4m 53.41s: Start check Blu-ray Ripper register status.
4m 53.41s: End check Blu-ray Ripper register status: Enable
4m 53.42s: OPList at BD Ripper : (4113.2),(4352.2),(4612.8)
4m 53.42s: Blu-ray ripper check watermark flag: 0
4m 53.42s: ------------------ convert work begin(1/1) ------------------
4m 53.43s: info: create config(bluray2video)
4m 53.43s: info: use profile(mkv.h264.aac)
4m 53.43s: info: bluray playlist(800),angle(0),chapter(3->3),BDAV(no)
4m 53.43s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
4m 54.84s: info: [Video]stream(4113) codec(h264) opcode(compress)
4m 54.84s: info: set output video frame_rate(24000/1001)
4m 54.85s: info: [Audio]stream(4352) codec(dca) opcode(compress) channel(8)
4m 54.85s: info: SubMode(Render) -- Display only forced subpicture(false)
4m 54.85s: info: [Sub]stream(4612) codec(pgssub) opcode(render) language(English)
4m 54.86s: try to use gpu acceleration(1) for video decoding
4m 54.86s: CUDA GPU acceleration for video decoding enabled
4m 54.86s: CUDA GPU acceleration for video encoding enabled
4m 54.86s: info: h264_encode: encode param profile(2) level(41) bitrate(7458)
4m 54.93s: --- connect filter failed(Module_CudaEncode 1) ---
4m 54.93s: ------------------ convert work failed ------------------
0m 09.33s: got bdmv
0m 09.45s: BEC 0
0m 09.66s: BEC 0
0m 10.20s: got vid
0m 12.16s: got vuk
0m 44.02s: got bdmv
