Does anyone know how or where i can check my LG WH08LS20 Blue Ray burners firmware. The LG website is not listing my model number. Any help would be appreciated. Thanks
Drives Firmware
GuestTags: None
Guest
Well i checked out firmware version and it says its the 1.00.00. Is there anywhere where i can find the update for this if there is one ????
Guest
Its ok i did more checking and found out i guess that my current firmware is the latest. Thanks guys for your help.
Anyone found an update for the wh08ls20 ? I have it and am running 1.0 howver I saw a few posts in other forums where they are running 2.0. Can't find anything on it.
This file does not recognize my drive:
http://www.firmwarehq.com/LG/WH08LS20/files.html
I have this drive but it came with an lg updater tool kit which may be available from their site. This is a wholsale drive but is the same as the BH08LS20 hope this helpsAMD Phenom II X4 965 BE @3960MHz
4G Geil ddr2 1066 (5-5-5-15) @1120MHz
ASUS M3N HT Deluxe Nvidia 780a chipset
2 XFX 9800GT SLI driver 197.45
LG WH08LS20 BD drive firmware updated
Windows7 Professional x64
Guest
Originally posted by Boston Joe View PostI did not get any software with my drive as it was OEM from Newegg, however, it is the same drive as the retail. I can't find the updater you reference anywhere on the net.
LG Blueray Burner
Singleman5, I have that same blueray burner. If you load the software DVD that came with your drive it has a LG Firmware tool you can install as part of the software package and it will tell you what version firmware you already have when you search for new firmware. Of course, I bought the retail version of the drive. Hope this helps..
Have you or anyone noticed any changes with the 1.0 to 2.0 upgrade?
Guest
Originally posted by Boston Joe View PostThanks. I must be going crazy, I thought I tried that same file a month ago and it did not find my drive. It worked and I am running 2.0.
I no longer use LG burners.
I am running 4 pioneer burners.
I would not mind replacing the DVD only drive with a Blu Ray player combo burner drive though. I am guessing you like Pioneer. Any thoughts on this one:
http://cgi.ebay.com/New-Pioneer-BDC-...item3ca97666f8
