GTX550Ti Drivers
    CPU/GPU GTX550Ti Drivers
    Folks, I am a great believer in 'If it ain't broke, don't fix it' --- My present GTX550Ti video card driver is quite an old one (296.10) but one that I know is stable and works just fine --Some updates totally messed up things hence my reasons for sticking with this version --- I am not a gamer but I use the GPU for my DVDFab rips etc. I am running Windows 7 64 bit --- I see that yet another updated version (314.07) is out and Windows Update has informed me that there is also a WHQL version as well --- So, do I update or not? If I update and find things are not right, then I can of course go back to my old version, but I'd rather not take any chances as I'm not that good with this kind of thing --- Any thoughts or suggestions would be greatly appreciated -- Has anyone out there updated and had problems or is all okay? --- Thanks in advance
    Go to your website for your grafhics card and up-date your driver from there!
    I have Evga GTX 460 oc, and I always up-date from there! I don't always trust Windows! Also W7 64
      I think you answered your own question!
        GeForce 550Ti Driver Updates
        Yes, I kind of did answer my own question - Thanks anyway
