Burning Blu-ray files to a disc
    Optical Drives Burning Blu-ray files to a disc
    Hello... I just decided to try blu-ray and I'd like to know if I need a special drive to burn blu-ray files onto a disc or my regular drive can do that using fab dvd blu-ray? also I have a double layer burner as well so... can I use that drive to do it?
    Thanks.
    Your "regular" DVD drive will not burn a Blu-ray. You will need a new drive.
      You'll need a Blu-ray reader and writer drive to do Blu-ray disc!
        You need a Blu-ray burner, something like this will do nicely;
          Yeah, Marty is right on, I use Pioneer burrner and they are great for burnning Blu-rays! Never had a problem out of mine!
