9030 v. 8228 re Target Folder
    Hi, I am not sure it is my problem or the program problem.
    In 8228, I am able to set the Target folder in any of the PCs or Servers within the network; while in 9030, I am limited to saving in the Target folder within the the local PC being used, which is quite inconvenient, because I will have to transfer to the server I wanted.
    Is there any solution now or in the near future?
    Many thanks,
    After exhausting search and trial within the program, I must conclude that the limited Target folder in Version 9 must have been overlooked by the developers.
    Therefore, please correct the problems as promptly as possible. If, however, such problems cannot be corrected, please advise alternative solutions.
    Many thanks,
