Using WHS 2011, and PS3 for streaming, question
    I usually back up my dvds (with DVD Ripper using DVDFAB) and I was able to get them down from 700Meg to 1Gig (files size).
    Now I am buying Blu-Ray movies and want to back them up and stream them too from WHS 2011, but was hoping to get them 1Gig or under in size with good sound and video.
    Is this Possible, and if so what is the best and easiest way to do this with DVDFAB?
    Thanks
    Yes it is possible but you will end up with quality similar to DVD, not Bluray.
    To acheive Bluray quality you will be looking betwee ~6-10 Gb.
      Thanks for replying.
      What would be the best/easiest way of doing that?
      Thanks
        Use the BluRay "Ripper" module and try out a couple of the profiles to see what suits you.
          I have been doing that. it obviously isn't that straight forward
            Well, you will need to give us some more detail on what you have tried.
              I've tried everything under avi. tried changing frames and resolution.
