Ver 9.0.3.2
    Ver 9.0.3.2
    Hi
    I hope someone has an answer for this problem. I installed the above version, as soon as it finished and offered to start I got the report an error form instead. When i said yes to restarting DVDFab 9 the same error reporting form popped up. I cannot get DVDFab 9 to start at all. I uninstalled it, re-installed and it does the same thing. I uninstalled it and replaced it with ver 9.0.2.8 which was working perfectly, now this is doing exactly the same. I have posted the error log as requested but am still having no luck. Anyone got any ideas?
    Use CCleaner or Revo Uninstaller, both are free and it will clean out all the leftovers from an unistall, then D/L a new installer and try that!
    I like Revo Uninstaller best, it has an advance cleaner option and works great!
