3d copy
    3d copy
    can anyone tell me how to backup bluray 3d been trying for two days after 4 hrs of ripping it says looking for blank media put blank media in and all it does is search for blank media if I go into my computer it shows the media in there but dvdfab cant find it please help using latest version of bluray copy and bd-25 media.
    check my tutorial, it's in german, but really simple, because it's with pictures and it works fine:
    Grüße...
    Puebi
      3d
      from what I can understand looks like what I did should it take 4 hrs
        yes, 3D copy (with shrinking) sometimes takes up to 4 hours. Do you use software encoding or CUDA? If CUDA, please switch zu software. And first make an ISO (~1 hour) and then from the ISO make the 3D copy to harddisk (with shrinking ~3-4 hours) and then burn with DVD-Fab Engine. It works, but if there are lots of streams in the stream folder (more than 4) then the film at BD will stutter...
        Grüße...
        Puebi
          3d
          the only problem i really have is when its done cant find the blank media
            if you put a blank media into your burner, DVDFab don't find it? Which Version do you use? 9.0.2.8 ? If you use the newer 9.0.3.3, then take the older, because 9.0.3.3. is beta... and 9.0.2.8 is latest final
            Grüße...
            Puebi
              using 9.0.3.2
                using 9.0.3.2
                also beta, please try 9.0.2.8 and report
                Grüße...
                Puebi
                  Hi terriablet
                  Give this post by my friend gleens a read through it my help
                  If all else fails, please post your internal log.
                  CBR929
                    3d
                    giving it a try thanks
                      3d
                      just to let you know the copy was a success going to try another and push my luck lol.
                        tried 9.0.2.8 didnt work no clone button when i burn it gives me a bunch of folders i cant do anything with
                          Yes, you can clone and the button is "hidden"
                          Insert a BD or DVD, click copy and burn and then you will be in clone mode... (you can see it in the right window...
                          and at the bottom you can choose, if you want to burn to BD/DVD or make an ISO...
                          Grüße...
                          Puebi
                            3d
                            ok did that but when i go to my clone file and hit mount to virtual drive and set my box to bd25 hit next goes to the 3d page i hit burn as bluray3d choose my burner and hit start it takes 25seconds to burn dont think its burning the movie
