Audio Question
    Audio Question
    I was wondering if it was possible to convert DVD audio to a cd. Thanks for your help.
    Yes, you used to be able to with DVD to Mobile but before replying to this thread I wanted to check again with a concert DVD and that option is greyed out (possibly broken).
    I will report this and see if we can get more info on this.
    Edit: actually it would rip the audio only to a MP3 file (I think) and you could burn that to a CD.
      Here is a guide that I'm also going over just to make sure I'm not doing something wrong
      Edit: Correction, I was doing something wrong!! Just follow the guide and all is good
        Thanks
        Thank you very much for the info.
