I have been unable to run any version 9 Dvdfab software Beta or Release and no Media player version past the last beta not sure if it may be related. I can run Version 8 with no issues whatsoever but now that version 8 has been stopped I have no other options when it stops working eventually.
As soon as I run dvdfab version 9 either the official or beta it shows a logo saying accessing server information and then stays like that. I even let it run for over 2 hours and nothing happened it crashed as soon as I clicked on the logo.
I have windows 7 64-bit thats fully updated and has the latest Nvidia drivers as of today.
I disabled all firewalls including Kaspersky and Windows Firewall.
I even uninstalled Kaspersky and removed any registry entries and fully uninstalled all dvdfab software and only installed 1 version at a time removing it and cleaning the registry and file/folder locations each time.
Here is the only log file in the dvdfab directory. I deleted the serial number part.
DVDFab 9.0.2.8 (2013/04/17 18:58:29)
0m 00.01s: Start preload dll...
0m 00.06s: Load dll successful.
0m 00.06s: Start load fabplay dll...
0m 00.12s: Load fabplay dll successful.
0m 00.12s: Windows os type is: 13.
0m 00.12s: Transfer settings successful.
0m 00.29s: GPUAccelerate: 28735
0m 00.29s: CUDA cap: 1
0m 00.29s: Support coreavc decode: 1
0m 00.29s: Graphics info: NVIDIA GeForce GTX 485M : 5.0 : 2.1
0m 00.29s: Qt Translator file load success
0m 00.37s: Start get sys number.
0m 00.39s: Serial number is:
0m 00.39s: Reg URL link is:
0m 00.39s: Version is: 9028
0m 00.39s: Product is: 2
0m 00.39s: Connect type is: 1
0m 01.09s: Times of connecting error is: 0
0m 01.09s: Parse string is: OV:9028
0m 01.09s: Parse string is: BV:9033
0m 01.40s: End check info.
0m 01.40s: Load config successful.
0m 01.84s: Profile Manager :: Begin Load Profile
0m 01.84s: Init profile data driver sucessful.
0m 01.84s: Init GPU settings sucessful.
0m 01.84s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 01.84s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 09.42s: Profile Manager :: End Load Profile
DVDFab 9.0.3.3 (2013/04/17 18:48:43)
0m 00.12s: Start preload dll...
0m 00.17s: Load dll successful.
0m 00.17s: Start load fabplay dll...
0m 00.23s: Load fabplay dll successful.
0m 00.23s: Windows os type is: 13.
0m 00.23s: Transfer settings successful.
0m 00.59s: GPUAccelerate: 28735
0m 00.59s: CUDA cap: 1
0m 00.59s: Support coreavc decode: 1
0m 00.59s: Graphics info: NVIDIA GeForce GTX 485M : 5.0 : 2.1
0m 00.59s: Qt Translator file load success
0m 00.68s: Start get sys number.
0m 00.68s: Serial number is:
0m 00.68s: Reg URL link is:
0m 00.68s: Version is: 9033
0m 00.68s: Product is: 2
0m 00.68s: Connect type is: 1
0m 01.37s: Times of connecting error is: 0
0m 01.37s: Parse string is: OV:9028
0m 01.37s: Parse string is: BV:9033
0m 01.71s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
0m 01.71s: End check info.
0m 01.71s: Load config successful.
0m 02.09s: Init profile data driver sucessful.
0m 02.09s: Init GPU settings sucessful.
0m 08.28s: Profile Manager :: End Load Profile
