error code
    error code
    i keep getting this error message.......task_2 failed! Error=122.......can anyone please help me???????????
    You couldn't have looked too hard on this forum!
      so how would i fix the problem cuz it use to work just fine
        Hi cmc44385
        The error is 122 HWS_FAILED_CALIBRATING 22 // Write failed at the beginning of the media (often a media that is poorly supported by the drive)
        Please post your internal and burn log.
        Thanks
        CBR929
          2013-04-18 00:33:42 ---- ******************** Log session stop 18-Apr 00:33:42.722 PID 7580********************
          2013-04-18 00:33:31 Info No disc in drive.
          2013-04-18 00:33:20 Error WRITE FAILED: Can't find write strategy at sector 16
          2013-04-18 00:33:20 Error Exception encountered in read thread [Access violation at address 083B6FF4 in module 'vso_hwe.dll'. Read of address 00000119]
          2013-04-18 00:33:20 Error Write error at 0 (16) - Code 05 21 02 [Illegal request, Invalid address for Write]
          2013-04-18 00:32:53 Info Write started 1821680 sectors to write
          2013-04-18 00:32:53 Info Init success: DVD+R
          2013-04-18 00:32:53 Info Writing speed requested x8.0, effective x8.0
          2013-04-18 00:32:53 Info Available write speed: 8x ,4x ,2.4x
          2013-04-18 00:32:53 Info Media ID: RITEK-F16-01
          2013-04-18 00:32:53 Info Media type: DVD+R
          2013-04-18 00:32:53 Info PIO Mode
          2013-04-18 00:32:53 Info Scanned files #15, folder #2 - total size 3729661952 b. (3.47 Gb.)
          2013-04-18 00:32:53 Info Inserted media type : DVD+R
          2013-04-18 00:32:51 Info Writable disc DVD+R inserted. Ready to write
          2013-04-18 00:32:29 Info Parsing disc ...
          2013-04-18 00:32:28 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
          2013-04-18 00:32:28 Info Drive has Serial ATA physical interface
          2013-04-18 00:32:28 Info New Drive selected : 0:1:0 - hp DVDRAM GT30L mP04 [F] (Ide)
          2013-04-18 00:32:19 Info Parsing disc ...
          2013-04-18 00:31:55 Info Disc ejected by user while parsing.
          2013-04-18 00:31:53 Info Parsing disc ...
          2013-04-18 00:28:26 Error WRITE FAILED: Can't find write strategy at sector 16
          2013-04-18 00:28:25 Error Exception encountered in read thread [Access violation at address 083B6FF4 in module 'vso_hwe.dll'. Read of address 00000119]
          2013-04-18 00:28:25 Error Write error at 0 (16) - Code 05 21 02 [Illegal request, Invalid address for Write]
          2013-04-18 00:28:03 Info Write started 2202480 sectors to write
          2013-04-18 00:28:03 Info Init success: DVD+R
          2013-04-18 00:28:03 Info Writing speed requested x8.0, effective x8.0
          2013-04-18 00:28:03 Info Available write speed: 8x ,4x ,2.4x
          2013-04-18 00:28:03 Info Media ID: RITEK-F16-01
          2013-04-18 00:28:03 Info Media type: DVD+R
          2013-04-18 00:28:03 Info PIO Mode
          2013-04-18 00:28:03 Info Scanned files #71, folder #2 - total size 4509427712 b. (4.20 Gb.)
          2013-04-18 00:28:03 Info Inserted media type : DVD+R
          2013-04-18 00:27:56 Info Writable disc DVD+R inserted. Ready to write
          2013-04-18 00:27:56 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
          2013-04-18 00:27:56 Info Drive has Serial ATA physical interface
          2013-04-18 00:27:43 Info New Drive selected : 0:1:0 - hp DVDRAM GT30L mP04 [F] (Ide)
          2013-04-18 00:27:13 Info Current Drive selected : 0:1:0 - hp DVDRAM GT30L mP04 [F] (Ide)
          2013-04-18 00:27:13 Info Using Advanced SPTI interface
          2013-04-18 00:27:13 Info System default language : English (United States)
          2013-04-18 00:27:13 Info User default language : English (United States)
          2013-04-18 00:27:13 Info DLL Version : 4.0.21.489
          2013-04-18 00:27:13 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
          2013-04-18 00:27:13 Info Version : 8, 2, 2, 8
          2013-04-18 00:27:13 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
          2013-04-18 00:27:13 Info OS : Microsoft Windows 7 Home Premium (Build 7600)
          2013-04-18 00:27:13 ---- ******************** Log session start 18-Apr 00:27:13.837 PID 7580********************
            Hi cmc44385
            First your discs are considered garbage, sorry.
            Consider picking up some quality discs like Verbatim with the AZO dye on the package label.
            Second your burning way to fast, try lowering your speed to 1/2 the rated speed of your discs, which in this case is 4x
            You may have better luck using ImgBurn as your burn engine, you will find it here http://www.imgburn.com/index.php?act=download and instructions in the link in my signature on setting it up with Fab.
            Remember to set up the AWS in ImgBurn to 1/2 the rated speed of these discs.
            Last you may be in PIO mode, Open Fab Click the Green top right > General > make sure Check for DMA Automatically is Checked and also Click the Reset DMA to the right click OK and restart Fab, you may also have to restart your computer.
            Hope this helps
            CBR929
              thank you so much for your help i will try and see if this works
