Asus BR burner problem
    Optical Drives Asus BR burner problem
    I have a new Asus BR burner Model SBW-06D2X-U for making backups. Unfortunately FAB doesn't see the drive. Win 7 sees it as a BR-RE drive. Anyone have one of these that works with FAB?
    You've checked in common settings to make sure it is listed and not excluded right?
      I have been using SBW-06D2X-U with FAB for two months now and I don't have any problem. It seems set up problem. Check your seeting in FAB.
      Note: I didn't do any set up in FAB. It was just plug and play.
