Conversion
    Conversion
    I have a question concerning conversion.
    I am using DVDFab v 9.0 .3.7.
    I have just purchased the Amazon Kindle Fire HD, and I'm having one heck of a time converting DVD or ISO to the Kindle Fire HD format.
    Guess the magic word is Conversion not Ripping.
    Can or would some one help me with this problem please?
    Also at the end of this conversion, will the subtitles be removed?
    Thank you kindly,
    apollo13
    You need to be using the Ripper module for what you want to do, conversion is for converting one file like an avi to an mp4 that have already been ripped for a mobile device.
      thank you for your reply 90312, I gave that a try with a full DVD, and as you said it seemed to do the job. Only one thing that I saw after this conversion or ripping, subtitles in the movies were still there. I went to the settings and could not find anything to remove subtitles do you have any suggestions?
      Thank you kindly,
      apollo13
        Yeah if you don't want any subtitles at all make sure all the boxes are cleared that I have outlined in the screenshot below. Any problem shout.
          Thank you 90312,
          Think i have it, guess a 65 yr. old fart can still learn a new trick or 2!!!!!!
          hagd,
          apollo13
            You're welcome pal and I'm not far behind you!
