I know it´s a minor problem, but i use an intel 6-core CPU (12 virtual cores) with DVDFab 9 and i can only choose 8 cores in the default settings. Yes i know, i can activate the additional four cores in the task-manager. But when i operate a task queue, all twelve cores only work in the first task. The second and the following tasks only use eight cores, which results in a significant slower working speed than possible. Is there a simple solution or is it possible to expand the core selction in the settings to "all cores", like it is in the task manager.
DVD-Fab 9 with 6-Core CPU
