I am having problems installing this beta. I have 9038 and back with no install problems. When I try to install DVDfab8039Beta it gets to a certain point then says it needs to close dvdfab 8 and 8Qt. This is weird because both of those programs are closed. Anyway at this point the installation hangs and I have to use task manager to stop the installation because it is not responding. Any suggestions? Thank you.
DVDfab9039Beta
I'd do the usual procedure of:-
1. Uninstall both Version 8 & 9 using their uninstallers.
2. Run CC Cleaner over your system until no registry errors are found. I have to usually run it 3 times. Make sure you use both the Cleaner and ensure all Old Prefetch data is cleaned and also the registry cleaner.
3. Redownload both installers and save to your hard disk.
4. Run the V9 installer as "Admin" and it should install OK.
Let us know how you get on.Last edited by GregiBoy; 05-14-2013, 09:24 PM."Beer is living proof that God loves us and wants us to be happy."- Benjamin Franklin 1706-1790
I did not do any of those things you suggested because I tried to install again with what I had and it worked. Thank you for the suggestions and I would have tried them but for some reason I opened my downloaded installer for DVDfab 9039Beta and it worked.
Every thing works well and it seems the compression on Blu-ray has improved noticeably. The only thing that needs fixing is the drag and drop for DVD.
Thank you again.
