Kindle Fire HD
    Kindle Fire HD
    Problem stated in (Post 55) seems to be still there!
    Ripping Time Difference:
    From Backup Dvd R1
    Title: Atlas Shrugger Part 1
    DVDFab Verison: (9.0.4.0): 2 hours 2 minutes
    Out put Size: 1.68 GB
    Frame Heigth: 1080
    Frame Width: 1920
    VS
    DVDFab Verison: (8.2.2.8): 44 minutes
    Out put Size: 1.11 GB
    Frame Heigth: 430
    Frame Width: 998
    Both Done with 2 Passes
    Is There a Season for the difference in Ripping time??
    Ty,
    apollo13
    hagd
    __________________________________________________ ____________
    Still won't Play in Kindle Fire HD
    DVDFab 9.0.4.0 (2013/05/16 07:40:40)
    0m 00.20s: Start preload dll...
    0m 00.23s: Load dll successful.
    0m 00.24s: Start load fabplay dll...
    0m 00.29s: Load fabplay dll successful.
    0m 00.29s: Windows os type is: 14.
    0m 00.31s: Transfer settings successful.
    0m 00.45s: GPUAccelerate: 3
    0m 00.45s: CUDA cap: 0
    0m 00.45s: Support coreavc decode: 0
    0m 00.45s: Graphics info: : :
    0m 00.46s: Load config successful.
    0m 00.48s: Qt Translator file load success
    0m 00.53s: Start get sys number.
    0m 00.53s: Serial number is: 00-1c-c0-b1-53-f6
    0m 00.53s: Reg URL link is:
    0m 00.53s: Version is: 9040
    0m 00.53s: Product is: 2
    0m 00.53s: Connect type is: 0
    0m 01.74s: Profile Manager :: End Load Profile
    0m 04.10s: Times of connecting error is: 0
    0m 04.10s: Parse string is: 2:8260762964
    0m 04.10s: Parse string is: 11:8260762964
    0m 04.10s: Parse string is: 20:8260762964
    0m 04.10s: Parse string is: 50:8260762964
    0m 04.10s: Parse string is: 80:8260762964
    0m 04.10s: Parse string is: 22:8260762964
    0m 04.10s: Parse string is: 21:8260762964
    0m 04.10s: Parse string is: 60:8260762964
    0m 04.10s: Parse string is: 70:8260762964
    0m 04.10s: Parse string is: 200:1379947896
    0m 04.10s: Parse string is: 1:12
    0m 04.10s: Parse string is: OV:9040
    0m 04.10s: Parse string is: BV:9039
    0m 04.10s: Parse string is: S:15b527d9bb61dea7d09266352e227190
    0m 04.13s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1
    file2dvd 1 file2bluray 1 file2mobile 1
    0m 04.13s: End check info.
    0m 04.25s: Init profile data driver sucessful.
    0m 04.25s: Init GPU settings sucessful.
    0m 08.20s: Begin init preview play engine.
    0m 08.44s: Init internal engine successful.
    0m 08.61s: Init burn engine successful.
    0m 08.81s: opening drive D
    0m 08.81s: opened i/o
    0m 08.82s: got media type 12
    0m 08.87s: got max lba 2202047
    0m 08.93s: got disc type 10
    0m 08.96s: type DVD-VIDEO
    0m 08.96s: volume label ATLAS_SHRUGGED
    0m 09.15s: opening drive E
    0m 09.15s: opened i/o
    0m 09.15s: failed to detect media type: sensekey 00 asc 00 acsq 00
    0m 09.16s: failed to get max lba: sensekey 02 asc 3A acsq 01
    0m 09.22s: internal path D:/VIDEO_TS/
    0m 09.23s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 09.44s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 09.85s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 10.05s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 10.46s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 10.67s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 11.07s: got copyright 0 0
    0m 11.58s: got udf/iso
    0m 12.53s: got discinfo
    0m 12.54s: pathplayer enabled
    0m 15.75s: button: vts_2 menu_1 pgc_1 cell_2 sector_494 count_4
    0m 24.57s: button: vts_2 menu_1 pgc_1 cell_3 sector_11224 count_4
    0m 24.63s: button: vts_2 menu_1 pgc_3 cell_1 sector_22551 count_7
    0m 24.82s: button: vts_2 menu_1 pgc_2 cell_1 sector_22371 count_15
    0m 24.84s: button: vts_2 menu_1 pgc_2 cell_2 sector_22399 count_15
    0m 24.86s: button: vts_2 menu_1 pgc_2 cell_3 sector_22432 count_15
    0m 24.88s: button: vts_2 menu_1 pgc_2 cell_4 sector_22464 count_15
    0m 24.90s: button: vts_2 menu_1 pgc_2 cell_5 sector_22492 count_15
    0m 24.92s: button: vts_2 menu_1 pgc_2 cell_6 sector_22520 count_15
    0m 24.93s: button: vts_2 menu_1 pgc_6 cell_1 sector_22582 count_6
    0m 30.88s: got dvdinfo
    0m 30.88s: opened dvd
    0m 35.90s: ========WorkAttr::SetSource=======
    0m 35.90s: Source Title :
    0m 35.90s: Source Video Size Original : 720 x 310
    0m 35.90s: Source Video Size Display : 854 x 368
    0m 35.90s: Source Video FPS : 24000 / 1001
    0m 35.90s: Source Video Bitrate : 1200
    0m 35.90s: Source Audio Bitrate : 448000
    0m 35.91s: Source Audio Channels : 6
    0m 35.91s: Source Audio Volume : 100
    0m 35.91s: Work Profile : Kindle Fire HD.default
    0m 36.13s: CommmandLine in fabopensource is
    0m 57.86s: ========WorkAttr::SetSource=======
    0m 57.86s: Source Title :
    0m 57.86s: Source Video Size Original : 720 x 310
    0m 57.86s: Source Video Size Display : 854 x 368
    0m 57.86s: Source Video FPS : 24000 / 1001
    0m 57.86s: Source Video Bitrate : 1200
    0m 57.86s: Source Audio Bitrate : 448000
    0m 57.86s: Source Audio Channels : 6
    0m 57.86s: Source Audio Volume : 100
    0m 57.86s: Work Profile : Kindle Fire HD.default
    4m 47.96s: Start check DVD Ripper register status.
    4m 47.96s: End check DVD Ripper register status: Enable
    4m 47.96s: OPList at DVD Ripper : (480.2),(128.2)
    4m 47.96s: DVD ripper check watermark flag: 0
    4m 47.97s: ------------------ convert work begin(1/1) ------------------
    4m 47.97s: info: create config(dvd2video)
    4m 47.97s: info: use profile(Kindle Fire HD.default)
    4m 47.97s: info: dvd playlist(1),angle(0),chapter(1->25)
    4m 47.97s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
    4m 50.96s: info: video stream[480][codec(mpeg2video) opcode(compress)]
    4m 50.96s: info: set output video frame_rate(30000/1001)
    4m 50.97s: info: audio stream[128][codec(ac3) channels(5) sample(48000) bitrate(448000)
    opcode(compress)]
    4m 50.97s: info: Subtitle Mode(NoSub) -- Display only forced Subtitle(false)
    4m 52.12s: info: h264_encode: encode param profile(1) level(40) bitrate(2300)
    66m 46.28s: audio_decode finish job
    67m 37.59s: info: h264_encode: encode param profile(1) level(40) bitrate(2300)
    128m 12.91s: audio_decode finish job
    128m 15.26s: audio_encode finish job
    129m 08.67s: ------------------ convert work finished ------------------
    __________________________________________________ _______________________________________
    Plays Just Fine In Kindle Fire HD
    DVDFab 8.2.2.8 (2013/05/16 09:59:08)
    0m 01.20s: Start preload dll...
    0m 01.24s: Load dll successful.
    0m 01.24s: Start load fabplay dll...
    0m 01.29s: Load fabplay dll successful.
    0m 01.29s: Windows os type is: 14.
    0m 01.31s: Transfer settings successful.
    0m 01.41s: GPUAccelerate: 3
    0m 01.41s: CUDA cap: 0
    0m 01.41s: Support coreavc decode: 0
    0m 01.41s: Graphics info: ATI Radeon HD 5770 : :
    0m 01.41s: Qt Translator file load success
    0m 01.45s: Load config successful.
    0m 01.48s: Init profile data driver sucessful.
    0m 03.36s: Init GPU settings sucessful.
    0m 03.36s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1
    file2dvd 0 file2bluray 1 file2mobile 1 filemover 1
    0m 03.36s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-
    ray2dvd:file2mobile:file2dvd:file2bluray:
    0m 03.57s: Config ExBar successful.
    0m 03.57s: dvd2dvd have 8 elements.
    0m 03.68s: dvd2mobile have 31 elements.
    0m 04.41s: blu-ray2blu-ray have 4 elements.
    0m 04.43s: blu-ray2mobile have 20 elements.
    0m 04.89s: blu-ray23d have 7 elements.
    0m 05.03s: blu-ray2dvd have 1 elements.
    0m 05.05s: file2mobile have 30 elements.
    0m 05.77s: file2dvd have 1 elements.
    0m 05.77s: file2bluray have 1 elements.
    0m 06.09s: Config work ui controls successful.
    0m 06.19s: Init burn engine successful.
    0m 06.24s: StartNotify successful.
    0m 06.24s: opening drive D
    0m 06.24s: opened i/o
    0m 06.24s: got media type 12
    0m 06.31s: got max lba 2202047
    0m 06.32s: got disc type 10
    0m 06.35s: type DVD-VIDEO
    0m 06.35s: volume label ATLAS_SHRUGGED
    0m 06.77s: internal path D:/VIDEO_TS/
    0m 06.77s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 06.99s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 07.21s: failed to report agid: sensekey 00 asc 00 acsq 00
    0m 07.43s: got copyright 0 0
    0m 08.42s: got udf/iso
    0m 09.33s: got discinfo
    0m 09.34s: pathplayer enabled
    0m 10.73s: button: vts_2 menu_1 pgc_1 cell_2 sector_494 count_4
    0m 19.48s: button: vts_2 menu_1 pgc_1 cell_3 sector_11224 count_4
    0m 19.55s: button: vts_2 menu_1 pgc_3 cell_1 sector_22551 count_7
    0m 19.72s: button: vts_2 menu_1 pgc_2 cell_1 sector_22371 count_15
    0m 19.73s: button: vts_2 menu_1 pgc_2 cell_2 sector_22399 count_15
    0m 19.75s: button: vts_2 menu_1 pgc_2 cell_3 sector_22432 count_15
    0m 19.77s: button: vts_2 menu_1 pgc_2 cell_4 sector_22464 count_15
    0m 19.78s: button: vts_2 menu_1 pgc_2 cell_5 sector_22492 count_15
    0m 19.78s: button: vts_2 menu_1 pgc_2 cell_6 sector_22520 count_15
    0m 19.80s: button: vts_2 menu_1 pgc_6 cell_1 sector_22582 count_6
    0m 24.55s: got dvdinfo
    0m 24.55s: opened dvd
    0m 29.67s: WorkAttr::Init Start
    0m 29.72s: WorkAttr::Init OK: Amazon.default
    3m 40.28s:
    3m 40.28s: info: create config(0)
    3m 40.28s: info: convert profile(Amazon.default)
    3m 40.28s: info: dvd playlist(1),angle(0),chapter(1->25),3D(0)
    3m 40.28s: info: streams((480.2)(128.2))
    3m 40.53s: info: set output video frame_rate(24000/1001)
    3m 41.69s: info: h264_encode: encode param profile(1) level(31) bitrate(1523)
    21m 36.96s: info: h264_encode: encode param profile(1) level(31) bitrate(1523)
    39m 36.63s:
    ------ finish mobile work ------
    The audio issue didn't get fixed in 9.0.4.0 still putting 6 audio channels in the file.
    The biggest thing I see in the time difference is the resolution. I find generally 8.2.2.8 is faster at encoding than the 9xxx versions and better at synchronizing the audio/video. I use it most all the time.
      I'm just stating what i'm finding in hopes for future inprovements to be made on the 9xxx verison.
      ty for ur reply,
      apollo13
      hagd
