My HP Win8 laptop doesn't want to burn correctly. I tried Les Mis a month ago and it started ok, but wouldn't open IMGBURN to finish process. That's ok cause I figured that out & made the copy. Now, when I put a blank in, it just ejects it out. If I wanted to change the settings so I can burn the copy later, what do I need to do?
Kind of confused on this cause everything is setup the same as on my Desktop.
I did burn another copy of Les Mis yesterday by opening the TS_video folder in IMGBURN
THANKS
THANKS
