error message
    error message
    what does error code 401 mean?
    15:59:53 Analyzing of DVD started
    16:00:17 Video quality is unreachable
    16:00:21 Task_1 failed! Error=401
    Hi, what's source do you use? please post your internal log.
      dvdfab 9.0.4.7
      DVDFab 9.0.4.7 (2013/07/09 15:51:36)
      0m 00.18s: Start preload dll...
      0m 00.24s: Load dll successful.
      0m 00.26s: Start load fabplay dll...
      0m 00.35s: Load fabplay dll successful.
      0m 00.35s: Windows os type is: 13.
      0m 00.53s: GPUAccelerate: 4
      0m 00.53s: CUDA cap: 0
      0m 00.53s: Support coreavc decode: 0
      0m 00.53s: Graphics info: Intel(R) Graphics Media Accelerator HD : :
      0m 00.54s: Load config successful.
      0m 00.56s: Transfer settings successful.
      0m 00.56s: Qt Translator file load success
      0m 00.62s: Start get sys number.
      0m 00.63s: Serial number is: 00-1e-64-90-2d-89:00-1e-64-90-2d-88
      0m 00.63s: Reg URL link is:
      0m 00.63s: Version is: 9047
      0m 00.65s: Product is: 2
      0m 00.65s: Connect type is: 0
      0m 01.91s: Times of connecting error is: 0
      0m 01.91s: Parse string is: 1:1395879662
      0m 01.93s: Parse string is: OV:9047
      0m 01.95s: Parse string is: BV:9046
      0m 01.96s: Parse string is: S:2faa9904e3f0da6a163cc552a9b3fd73
      0m 02.16s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
      0m 02.16s: End check info.
      0m 02.40s: Init GPU settings sucessful.
      0m 02.69s: Profile Manager :: End Load Profile
      0m 04.75s: Begin init preview play engine.
      0m 04.77s: Init DirectShow engine successful.
      0m 05.35s: Init burn engine successful.
      0m 05.69s: opening drive F
      0m 05.70s: opened i/o
      0m 05.72s: got media type 4
      0m 15.97s: failed to get max lba: sensekey 02 asc 3A acsq 02
      0m 15.98s: opening drive F
      0m 16.12s: opened i/o
      0m 16.12s: CommmandLine in fabopensource is
      0m 35.78s: opening drive F
      0m 36.30s: opened i/o
      0m 36.31s: got media type 4
      0m 36.58s: got max lba 4169919
      0m 36.73s: got disc type 10
      0m 36.92s: type DVD-VIDEO
      0m 36.92s: volume label TEMPTATION_CONFESSIONS_OF_A_MARR
      0m 37.06s: internal path F:/VIDEO_TS/
      0m 37.61s: got copyright 1 fe
      0m 38.63s: got udf/iso
      0m 47.67s: got discinfo
      0m 47.85s: pathplayer enabled
      0m 51.47s: button: vts_26 menu_1 pgc_8 cell_2 sector_18212 count_4
      1m 08.84s: button: vts_26 menu_1 pgc_7 cell_1 sector_264 count_4
      1m 26.28s: button: vts_26 menu_1 pgc_9 cell_1 sector_35342 count_6
      1m 26.31s: button: vts_26 menu_1 pgc_10 cell_1 sector_35383 count_7
      2m 30.75s: button: vts_26 menu_1 pgc_15 cell_1 sector_35569 count_7
      2m 30.98s: button: vts_26 menu_1 pgc_16 cell_1 sector_35631 count_4
      2m 36.17s: button: vts_26 menu_1 pgc_11 cell_1 sector_35424 count_7
      2m 36.19s: button: vts_26 menu_1 pgc_12 cell_1 sector_35463 count_7
      2m 36.22s: button: vts_26 menu_1 pgc_13 cell_1 sector_35498 count_7
      2m 36.24s: button: vts_26 menu_1 pgc_14 cell_1 sector_35534 count_6
      2m 42.61s: got dvdinfo
      2m 42.84s: opened dvd
      3m 01.70s: DVD Copy
      3m 01.70s: Source: F:/
      3m 01.71s: SourceSize: 52463 MB
      3m 01.71s: OutputSize: 4300 MB
      5m 37.55s: opening drive F
      5m 37.64s: opened i/o
      5m 37.66s: got media type 4
      5m 38.13s: got max lba 4169919
      5m 38.30s: got disc type 10
      5m 38.40s: type DVD-VIDEO
      5m 38.41s: volume label TEMPTATION_CONFESSIONS_OF_A_MARR
      5m 44.05s: opening drive F
      5m 44.07s: opened i/o
      5m 45.07s: got max lba 4169919
      5m 45.22s: got disc type 10
      5m 45.32s: internal path F:/VIDEO_TS/
      5m 45.51s: got copyright 1 fe
      5m 46.49s: got udf/iso
      5m 54.84s: got discinfo
      5m 55.03s: pathplayer enabled
      5m 58.67s: button: vts_26 menu_1 pgc_8 cell_2 sector_18212 count_4
      6m 16.16s: button: vts_26 menu_1 pgc_7 cell_1 sector_264 count_4
      6m 33.67s: button: vts_26 menu_1 pgc_9 cell_1 sector_35342 count_6
      7m 24.15s: button: vts_26 menu_1 pgc_15 cell_1 sector_35569 count_7
      7m 24.65s: button: vts_26 menu_1 pgc_10 cell_1 sector_35383 count_7
      7m 38.12s: button: vts_26 menu_1 pgc_11 cell_1 sector_35424 count_7
      7m 38.14s: button: vts_26 menu_1 pgc_12 cell_1 sector_35463 count_7
      7m 38.17s: button: vts_26 menu_1 pgc_13 cell_1 sector_35498 count_7
      7m 38.19s: button: vts_26 menu_1 pgc_14 cell_1 sector_35534 count_6
      7m 38.37s: button: vts_26 menu_1 pgc_16 cell_1 sector_35631 count_4
      7m 49.63s: got dvdinfo
      7m 49.86s: opened dvd
      8m 17.09s: DVD Copy
      8m 17.10s: Source: F:/
      8m 17.10s: SourceSize: 52463 MB
      8m 17.10s: OutputSize: 4300 MB
      10m 25.85s: opening drive F
      10m 25.92s: opened i/o
      10m 25.93s: got media type 5
      10m 25.95s: got max lba 0
      14m 19.83s: opening drive F
      14m 19.86s: opened i/o
      14m 19.88s: got media type 4
      14m 29.80s: failed to get max lba: sensekey 02 asc 30 acsq 00
      <I THINK THATS THE RIGHT ONE>
        Hi cmc44385
        Please make sure that your using main movie, and not full disc.
        You may also try the latest version of 8 found here
        There will also be a new release of Fab to deal with this movie.
        Hope this helps
        CBR929
