ISO makeing problem
    ISO makeing problem
    Hi, i have of a question about trying to make an ISO. After it copys it, it spits out the disc and attempts to make a ISO but fails, saying error 121. i set the route for the iso to be my desktop and it still failed. how do i fix this so it dose give me an iso?
    that strange as I am doing an iso right now of Rambo and it seems to be working but for now can you read theand post the information it say to post to this thread of yours. This way can see what the problem is for you
      14:22:02: Analyzing of DVD started
      14:22:02: Analyzing of DVD completed successfully
      14:22:02: Copy process started
      14:56:21: Copy process completed successfully
      14:56:21: Create ISO process started
      14:56:39: Create ISO process started
      14:56:42: Task_2 failed! Error=121
      I useing DVDFab through Parrallels right on my mac which is running OS 10 if that counts for anything. It will bring up a pop-up and say "DVD burn failed try again?" and untill i say no it keeps doing the "Create ISO process started"
        Well then that the problem as iso for windows is a different iso for a mac. What you need to do is save as TS folder and then use a mac program to convert that to an iso
          do by chance know of a program that can convert from TS folder to ISO for windows or mac?
            you would need something for mac and I believe mac comes with it installed already
