Unable to copy blu-ray after upgrading to 9.0.4.7
    As the thread's title says, I can't copy blu-ray with ver. 9.0.4.7
    I get the following prompt whenever I put a blu-ray into my drive:
    Internet is required to open this Blu-ray disc.
    If you have firewall software installed, please configure it to allow DVDFab to access the internet.
    The only firewall on my system is Windows Firewall, and I have it set so DVDFab9 can access the net unrestricted.
    Here's an example from the log:
    0m 04.27s: Version is: 9047
    0m 04.27s: Product is: 2
    0m 04.27s: Connect type is: 0
    0m 04.91s: Times of connecting error is: 0
    0m 04.91s: Parse string is: 2:1390705567
    0m 04.91s: Parse string is: 11:1390705567
    0m 04.91s: Parse string is: 20:1390705567
    0m 04.91s: Parse string is: 50:1390705567
    0m 04.91s: Parse string is: 80:1390705567
    0m 04.91s: Parse string is: 22:1390705567
    0m 04.91s: Parse string is: 21:1390705567
    0m 04.91s: Parse string is: 60:1390705567
    0m 04.91s: Parse string is: 70:1390705567
    0m 04.91s: Parse string is: 61:1390705567
    0m 04.91s: Parse string is: 62:1390705567
    0m 04.91s: Parse string is: 1:0
    0m 04.91s: Parse string is: OV:9047
    0m 04.91s: Parse string is: BV:9046
    0m 04.91s: Parse string is: S:5ba4078e275aef4ed71e2e70d99ec7fc
    0m 05.27s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
    0m 05.27s: End check info.
    0m 05.63s: Init GPU settings sucessful.
    0m 21.00s: Begin init preview play engine.
    0m 21.96s: Init internal engine successful.
    0m 23.99s: Init burn engine successful.
    1m 04.67s: opening drive E
    1m 04.67s: opened i/o
    1m 04.71s: opening drive F
    1m 04.72s: opened i/o
    1m 04.79s: opening drive G
    1m 04.82s: opened i/o
    1m 04.84s: CommmandLine in fabopensource is
    1m 47.16s: opening drive G
    1m 48.30s: opened i/o
    1m 48.30s: got media type 15
    1m 48.69s: got max lba 23083487
    1m 49.48s: got disc type 20
    1m 49.48s: type Blu-ray BDMV
    1m 49.48s: volume label SPICE_AND_WOLF
    1m 49.52s: internal path G:/BDMV/
    1m 49.53s: aacs 1 bd+ 0
    1m 49.80s: got bdmv
    1m 49.80s: movie name: Spice and Wolf||SPICE_AND_WOLF
    1m 49.82s: Vendor: HL-DT-ST
    1m 49.82s: Product: BD-RE WH12LS39
    1m 49.82s: Revision: 1.00
    1m 49.82s: Vendor specific:
    1m 49.82s: AACS version: 1
    1m 49.82s: Number of concurrent AGIDs: 1
    1m 49.82s: Supports bus encryption: YES
    1m 49.82s: Supports binding nonce generation: YES
    1m 49.82s: Supports Hybrid discs: NO
    1m 49.82s: got agid 0
    1m 49.83s: sent host cert chal
    1m 49.84s: got drive cert chal
    1m 49.84s: BEC 1
    1m 49.84s: DRIVE_VENDOR 0x0074
    1m 49.86s: got drive key
    1m 49.86s: got host key signature
    1m 49.86s: verified drive signature
    1m 49.86s: verified host signature
    1m 49.88s: sent host signature and key point
    1m 49.88s: got bus key
    1m 49.91s: got agid 0
    1m 49.92s: sent host cert chal
    1m 49.93s: got drive cert chal
    1m 49.93s: BEC 1
    1m 49.93s: DRIVE_VENDOR 0x0074
    1m 49.95s: got drive key
    1m 49.95s: got host key signature
    1m 49.95s: verified drive signature
    1m 49.95s: verified host signature
    1m 49.97s: sent host signature and key point
    1m 49.97s: got bus key
    1m 49.98s: got volume id
    1m 49.98s: got volume id mac
    1m 49.98s: volume id is correct
    1m 49.98s: got vid
    1m 50.43s: blu-ray CB86FAC502F21E612B3E5472A261E084D1A72B6F
    1m 50.87s: cert BEE=0x00 same
    1m 50.97s: error curl post: Failure when receiving data from the peer
    1m 50.97s: failed to open 302
    It appears that this title is not yet supported on the server, keep an eye on the Decryption Updates forum.
      Thanks for the quick response, but it does raise another question.
      I've just upgraded to 9.0.5.0 and tossed in a blu-ray I have copied before, Fate/Stay Night: Unlimited Blade Works. It isn't on the " Recent Updates BD+ Support Update" or "BD+ Update History Look for older titles here" threads. I couldn't find anything on it using the forum search either. Unfortunately, I met with the exact same result as I did for the disc I originally posted about.
      So, the question is: why can now no longer copy some BD that I could previously?
      Thanks in advance.
        Please visit the following link to make sure the network is working:
        You should see "IS OK".
        http://www.dvdfab.cn
          Morgen
          weiß jemand,warum mein DVDFab 8.1.9 Bluray Copy ,nicht die neue Bluray"The Last Stand" öffnen kann?
          ist die 1.Scheibe,die nicht geht.
            @fengtao: Thanks for the tip.
            @Boldi:
            (English)
            I don't know why you'd have that problem, but I am not technical support.
            If you have not done so already, you should try starting a posting in the Deutsch forum.
            (Google Übersetzt)
            Ich weiß nicht, warum du dieses Problem hätte, aber ich bin nicht technische Unterstützung.
            Wenn Sie nicht bereits getan haben, sollten Sie versuchen, die Gründung eines Buchung im Deutsch Forum.
