This is going to be a WAG.
I suspect it was done to correct a technical issue. Dolby Surround/ProLogic is not 6-channel audio. Never has, never will. It is only two physical stereo channels with an out-of-phase mono rear channel. The Dolby Surround/ProLogic "decoder" strips out the rear channel and feeds it to the rear channel speakers. It also "decodes" center channel audio and feeds that to the center speaker and what remains of the two channels is fed to the left and right speakers.
All other multi-channel Dolby encodings are done via the Dolby AC3 specification.
Since I've never had a version that old, it would surprise me if it ever did have 6-channel audio in anything but Dolby Digital or DTS. That is because it is impossible to do phase encoded audio (which is what Dolby Surround is) with 6 channels.
