more copys
    more copys
    hi all,
    have just used v9055 for the first time, and see that it does not give you the option to record a second disc after the process completes, while this is not a problem it is sometimes useful to be able to run a second copy .
    has this been left off on purpose or by mistake ?
    regards to all
    Hi mickey
    Please see this thread
    CBR929
      hi CBR929,
      Thanks for your reply and the redirect.
      I just like to say that i do not make lots of pirate copys, it is just that i sometime need a second copy due a faulty disc or copy.
      anyway thanks
      regards
        Originally posted by mickey View Post
        hi CBR929,
        anyway thanks
        regards
        Hi mickey
        I'm sorry, it was not my intention to accuse you of making pirated copy's.
        If using full disc or clone/burn you will see an option in 9055 where you will select the number of copy's to make in Fab settings.
        It is very easy to miss.
        I have not seen it in main movie, but will try to see if it is also there.
        Again I'm sorry.
        CBR929
        Edit: It is also in main movie once you hit the next button, there is a little box, "backup quantity" where you will select the number of copies to make.
          hi CBR929,
          thanks for that.
          regards
            hi CBR929,
            thanks for that.
            regards
            Hi mickey
            No problem!!!
            This is a new feature for copies and it is easy to miss this setting.
            Cheers
            CBR929
