Can anyone please help? I have the DVD Creator and it has not worked for me for at least a week now.
When I try to create DVDs using the DVD Creator version 8 it crashes every time. I drag the files into the folder and it disappears and crashes every time.
When I tried the DVD Creator with version 9 it simply does not work at all no matter what I do. Nothing comes out on a blank DVD and I've followed the instructions to the letter and use MP4 files. Nothing at all. So, I can't create DVDs with the version 8 one and the version 9 one does absolutely nothing.
I'm using a Toshiba laptop with Windows 8 running. I use the most current DVD Copy program just fine but I feel like I threw my money out the window since I cannot use DVD Creator at all no matter what I do.
Can anyone please help? If DVD Creator no longer works is it possible to get a refund or credit? Is there any other program anyone can recommend that will work? I need to be able to create DVDs for my business and DVD Creator simply does not work any more no matter what I do.
- Benjamin Franklin 1706-1790
