Question on audio
    Other Question on audio
    I was wondering if it is possible to copy a dvd, save the audio and burn it to an audio cd? Like getting the tracks from a concert dvd?
    You can get the audio by using the "Audio Only" profile of the RIPPER module.
    Fab has no way to burn this back to an Audio CD format though and you will have to use other software to do this.
    Most optical drives come with software that will.
