command line
    command line
    Is there any difference between the command line usage of DVDFab9 over DVDFab8? I have a batch file that works fine under v8.2.2.9 but causes a crash dump with V9. This is the batch file (based on an example posted by another user on this forum.
    @echo off
    echo DVDFAB Batch Conversion Script - DVD9 to DVD5
    rem **********************************************
    rem Set Enviromental variables for File locations
    set DVDSOURCE=C:\Ripcord
    set SRCDRV=C:
    set DESTDIR=K:
    set DESTSUBDIR=ripcord
    set DESTTYPE=iso
    rem Set Enviromental variable for DVDFAB Version
    rem
    rem Note: (x86) is usualy found on Windows 7 64bit
    rem Note: The current version of DVDFAB 9 will crash
    if exist "C:\Program Files (x86)\DVDFab 9\DVDFab.exe" (
    set DVDFAB="C:\Program Files (x86)\DVDFab 9\DVDFab.exe"
    goto mDVD )
    if exist "C:\Program Files\DVDFab 9\DVDFAB.exe" (
    set DVDFAB="C:\Program Files\DVDFab 9\DVDFAB.exe"
    goto mDVD )
    if exist "C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe" (
    set DVDFAB="C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe"
    goto mDVD )
    if exist "C:\Program Files\DVDFab 8 QT\DVDFAB.exe" (
    set DVDFAB="C:\Program Files\DVDFab 8 QT\DVDFAB.exe"
    goto mDVD )
    :mDVD
    rem set DVDFAB="C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe"
    set MODE="FULLDISC"
    set AUDIO="English"
    set OUTDISC="dvd5"
    rem For-Do Loop
    rem
    rem Note: the code ('dir /B /S "%DVDSOURCE%\*.iso"') generates a list of files
    rem using the 'dir' command with the /Brief and /SubDirectories. The 'tokens' are
    rem a line out of the list (the 'F'option) that is in the form of a filename
    rem (fullpath - %%x)
    rem
    for /F "tokens=*" %%X in ('dir /B /S "%DVDSOURCE%\*.iso"') do (
    echo "%%X"
    echo "%%~PX%%~nX.%DESTTYPE%"
    echo "%%~nX"
    echo "%%~xX"
    echo "%DESTDIR%\%DESTSUBDIR%\%%~nX.%DESTTYPE%"
    echo "%DESTDIR%%%~PX%%~nX_dvd5.%DESTTYPE%"
    pause
    rem Check to make sure our dvd9 to dvd5 converted file does not exsist
    if not exist "%DESTDIR%%%~PX%%~nX_dvd5.%DESTTYPE%" (
    rem Invoke the command line mode of DVDFAB
    echo /MODE %MODE% /AUDIO %AUDIO% /SRC "%%X" /DEST "%DESTDIR%%%~PX%%~nX_dvd5.%DESTTYPE%" /OUTDISC %OUTDISC%
    /REMOVEHDAUDIO "no" /CLOSE
    %DVDFAB% /MODE %MODE% /AUDIO %AUDIO% /SRC "%%X" /DEST "%DESTDIR%%%~PX%%~nX_dvd5.%DESTTYPE%" /OUTDISC %OUTDISC%
    rem rename the source file so it won't get proceeses again if this batch file is stopped and then started again
    echo "%%X" "%%~nX.xso"
    ren "%%X" "%%~nX.xso"
    ) else (
    rem if the converted file already exsist, say so
    echo "File exists "%DESTDIR%%%~PX%%~nX_dvd5.%DESTTYPE%"
    rem Close of For-Do Loop
    pause
    set MODE="FULLDISC"
    The crash is caused by "/Audio %Audio%" parameter, please remove it first, and we will fix it ASAP.
    Fulldisc does not support to select audio and subtitle. DVDFab should filter the parameter which invalid.
      Great, thanks!
