This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
Both Beta 6 and 7 work with WW Z. There seems, however, to be a new wrinkle thrown into the process--at least as far as I can tell.
After copying and burning, first on 6 and then on 7, the disk would load into the DVD player but would not start via the remote control. When played on the computer, though, they opened and played fine. When put back into the DVD, pressing play manually started the previews and the movie itself.
This anomaly exists on both beta versions.
My player--a Toshiba 1080p--has two PLAY buttons, a general and a resume.
Pressing the resume button after inserting the disk starts the DVD, and then pressing the SKIP button advances the chapters.
Don't know if this will help anyone with playing issues, but that's the way I'm getting WW Z to play.
I am using DVD Copy 8.2.2.9 and am having trouble with World War Z showing it copied disk in 3.0 seconds, which I know is not right. There are no fixes that I know of. Can anyone tell me what is wrong?
you will have to use version 9xxx for world war z with "pathplayer always
enabled"
