Thanks GregiBoy!!!
    Thanks GregiBoy!!!
    Your advice and links have been very helpful in my quest to convert my DVD collection. Thanks for your hard work. Question for you: When using generic.avi.h264 to rip DVDs what framerate should I use? Does it matter? Thanks again...
    Yup, GregiBoy has done an outstanding job with his guides and info.
    I suspect GregiBoy is sound asleep right now, but to answer your question,
    try 23.976 fps.
    And this may have been just your phrasing, but you should always rip the files to your hdd prior to any conversions...
      Thanks maineman. I have been ripping to hdd so is 30 framerate overkill?
        I wish GregIBoy were here...maybe I'll wake him up...hehehe.
        As I understand it, theatrical movies are normally 24 fps. When transferred to NTSC TV, I believe the effective rate slows to 23.976 fps and with transfer to PAL TV, speeds increase to about 25 fps.
        Initially, Fab's Mobile app had a default setting of 29.97 fps.
        Most of us, including me, did not experience any issues.
        My guess is that any predisposition for errors is minimized with an fps of 23.976.
          Thank you for your help.
            GregiBoy finally woke up....
            As a general rule use "Same as source".
            Most players can handle different framerates and this means less interpolation by the software and means best quality.
              About time!...
                Thanks Maineman!!
                It was only 4:55 am when I posted.
                Originally posted by maineman View Post
                About time!...
                  OT again...sorry
                  Yah, yah, yah...I was up at 4 AM my time. Ya big wuss!
                  Course, it was because I couldn't get back to sleep...
                  I'm really not liking this getting old stuff.
                  Howzabout you?
                    I wasn't liking this getting old stuff either until I got divorced. Then I discovered this new thing called "WOMEN" !!!!
                      I wasn't like this getting old stuff either until I got divorced. Then I discovered this new thing called "WOMEN" !!!!
                      I woulda got divorced also if I had not discovered " Women ". ( Just joking)
