DVDFab: updating
    DVDFab: updating
    im still using ver 4, when i update it copies ok but when i put a blank disc in, to burn, it says i need a duel layer disc to copy it, never have this prob with ver 4, sorry if its been asked b4 can someone help please.
    many thanks
    zofo
    At the bottom left hand side of the main screen you will see a quality box with a drop down arrow, make sure you have it set for DVD5 for SL and DVD9 for DL media Also how are you updating it when version 4 is no longer supported?
    Paid Not To Work
    US Navy Retired ( 20 Years )
    Proudly Served On
    USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
    6 trips to the Gulf Of Tonkin
      Sorry sorta misunderstood, what version did you update too ?
      Paid Not To Work
      Proudly Served On
        Sounds like the trial version has ran out and now it will not convert down to SL disc.
        Removal of new protections may not be available yet in the free version of DVDFab (HD Decrypter)
        Help Us Help You :
        Troy's excellent tutorial on Setting up ImgBurn with DVDFab :
        I use Taiyo Yuden and Verbatim media mainly.
        Trying Falcon D/L media
        I use ImgBurn as my main burning engine
        Free Media Player VLC
