Can't Rip Original Superman DVD
    The disc begins to decrypt at approx. 2mbps, then gets as fast as 5mbps,
    then begins slowing down at the 75% mark until it completely stops dead
    by the 83% complete mark.
    Didn't know if anyone else liked that movie enough to try to copy it besides
    me . . ha ha.
    Thanks,
    Mr. Rush
    With the lack of helpful information posted all I can suggest is try turning off pathplayer.
    If it is off then turn it on.
      The older movies like the Superman group did require me to turn off pathplayer.
      Hope this helps
      Using DVDFab vers 5.3.2.0 on Win XP
      Removal of new protections may not be available yet in the free version of DVDFab (HD Decrypter)
      Help Us Help You :
      Troy's excellent tutorial on Setting up ImgBurn with DVDFab :
      I use Taiyo Yuden and Verbatim media mainly.
      Trying Falcon D/L media
      I use ImgBurn as my main burning engine
      Free Media Player VLC
        Thanks
        Thanks to all for your support. I'll try tweaking pathplayer.
