Hi, I'm hoping someone less novice can assist.
I can't seem to get a double layer burn to work. New HP drive (checked all firmware/drivers up to date),and I'm using the 6.2.0.5 version of DVDFab. Additionally, I changed the setting for the write speed to 4, yet it still shows 8 (yes, I closed it and reopened.) Here is the error log: I have noted the errors in color:
2009-12-29 23:52:23 ---- ******************** Log session stop 29-Dec 23:52:23.859 PID 844********************
2009-12-29 23:51:26 Info Disc ejected by user.
2009-12-29 23:50:46 Info Writable disc DL DVD+R inserted. Ready to write
2009-12-29 23:50:24 Info Parsing disc ...
2009-12-29 23:49:50 Info Disc ejected by user.
2009-12-29 23:48:28 Info Writable disc DL DVD+R inserted. Ready to write
2009-12-29 23:48:06 Info Parsing disc ...
2009-12-29 23:47:40 Error INIT ERROR: Writing device initialization failed - sense: Code 05 26 00 [Illegal request, Invalid field in Parameter list]
2009-12-29 23:47:40 Error Init DVD+R Dual Layer: Write cancelled, Your media is still usable.
2009-12-29 23:47:40 Error Init DVD+R Dual Layer: Failed to set layer change to LBA 2223856 (4.24 Gb.) - Code 05 26 00 [Illegal request, Invalid field in Parameter list]
2009-12-29 23:47:40 Info Writing speed requested x8.0, effective x8.0
2009-12-29 23:47:40 Info Layer break set by user at sector 2223856
2009-12-29 23:47:40 Info Available write speed: 8x ,6x ,4x
2009-12-29 23:47:40 Info Media ID: RITEK-S04-42
2009-12-29 23:47:40 Info Media type: Dual Layer DVD+R
2009-12-29 23:47:38 Info Write started
2009-12-29 23:47:36 Info Writable disc DL DVD+R inserted. Ready to write
2009-12-29 23:47:14 Info Parsing disc ...
2009-12-29 23:29:18 Info Disc (DVD-ROM) not emtpy.
2009-12-29 23:29:16 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2009-12-29 23:29:16 Info Drive has Serial ATA physical interface
2009-12-29 23:29:16 Info New Drive selected : 0:0:0 - HP DVD Writer 1170d DH22 [F] (Usb)
2009-12-29 23:28:26 Info Current Drive selected : 0:0:0 - LITE-ON CD-RW SOHR-5238S 4S05 [D] (Ide)
2009-12-29 23:28:26 Info Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
2009-12-29 23:28:26 Info System default language : English (United States)
2009-12-29 23:28:26 Info User default language : English (United States)
2009-12-29 23:28:26 Info DLL Version : 4.0.5.464
2009-12-29 23:28:26 Info DLL : C:\Program Files\DVDFab 6\vso_hwe.dll
2009-12-29 23:28:26 Info Version : 6, 2, 0, 5
2009-12-29 23:28:26 Info ExeName : C:\Program Files\DVDFab 6\DVDFab.exe
2009-12-29 23:28:26 Info OS : Microsoft Windows 2000 Professional (Build 2195: Service Pack 4)
2009-12-29 23:28:26 ---- ******************** Log session start 29-Dec 23:28:26.828 PID 844********************
Other settings: Booktype set proper for DVD+R DL; DMA enabled, but as you can see...it failed, and has consistently no matter what DL I try. If anyone here can decypher the error and assist, I sure would be grateful, and admit I am no wizard with this. ...Thank you!!! MzHarleyD.
