Dvdfab 9.0.7.2 crashes
    Updated to 9.0.7.2 and it crashes. Went back to 9.0.7.1 and ok.
    Here is log:
    DVDFab 9.0.7.2 (2013/10/20 00:04:34)
    0m 00.06s: Start preload dll...
    0m 00.10s: Load dll successful.
    0m 00.10s: Start load fabplay dll...
    0m 00.16s: Load fabplay dll successful.
    0m 00.16s: Transfer settings successful.
    0m 00.16s: info: fabcheck logpath= E:\Matt\Documents\DVDFab9\Log\
    0m 00.18s: fab_check_gpu is running ...
    0m 00.76s: fab_check_gpu run successful
    0m 00.76s: info: recommand= 0, Shrink= 0, cuda_cap= 0 , cpu_count= 8
    0m 00.76s: GPUAccelerate: 455
    0m 00.76s: CUDA cap: 0
    0m 00.76s: Support coreavc decode: 0
    0m 00.76s: Graphics info: AMD Radeon HD 7800 Series : :
    0m 00.76s: Load config successful.
    0m 00.76s: Windows os type is: 14.
    0m 00.80s: Parse string is: 20:1422726227
    0m 00.80s: Parse string is: 21:1422726227
    0m 00.80s: Parse string is: 22:1422726227
    0m 00.80s: Parse string is: 11:8260762964
    0m 00.80s: Parse string is: OV:9072
    0m 00.80s: Parse string is: BV:9072
    0m 00.80s: Parse string is: S:7e8c9f8f58034b9071aa092a039b5fb5
    0m 00.80s: Option check status: Local
    0m 00.80s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
    0m 00.80s: Start get sys number.
    0m 00.80s: Serial number is: c8-60-00-c5-30-25
    0m 00.80s: Reg URL link is:
    0m 00.80s: Version is: 9072
    0m 00.80s: Product is: 2
    0m 00.80s: Connect type is: 0
    0m 00.80s: Init GPU settings successful.
    0m 00.80s: CommmandLine:
    0m 01.17s: Begin init preview play engine.
    0m 01.25s: Init internal engine successful.
    0m 01.26s: Times of connecting error is: 0
    0m 01.27s: Parse string is: 20:1422726227
    0m 01.27s: Parse string is: 21:1422726227
    0m 01.27s: Parse string is: 22:1422726227
    0m 01.27s: Parse string is: 11:8260762964
    0m 01.27s: Parse string is: OV:9072
    0m 01.27s: Parse string is: BV:9072
    0m 01.27s: Parse string is: S:de585e4b55f4767f7ecd7953d5ba5680
    0m 01.27s: Option check status: NewWork
    0m 01.27s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
    0m 01.36s: locale: en_US
    lan: ENU
    default font: ms shell dlg
    use font: Arial
    fonts: Aharoni,Aldhabi,Andalus,Angsana New,AngsanaUPC,Aparajita,Arabic Typesetting,Arial,Arial Black,Batang,BatangChe,Browallia New,BrowalliaUPC,Calibri,Calibri Light,Cambria,Cambria Math,Candara,Comic Sans MS,Consolas,Constantia,Corbel,Cordia New,CordiaUPC,Courier,Courier New,DaunPenh,David,DFKai-SB,DilleniaUPC,DokChampa,Dotum,DotumChe,Ebrima,Est rangelo Edessa,EucrosiaUPC,Euphemia,FangSong,Fixedsys,Fran klin Gothic Medium,FrankRuehl,FreesiaUPC,Gabriola,Gadugi,Gauta mi,Georgia,Gisha,Gulim,GulimChe,Gungsuh,GungsuhChe ,Impact,IrisUPC,Iskoola Pota,JasmineUPC,Javanese Text,KaiTi,Kalinga,Kartika,Khmer UI,KodchiangUPC,Kokila,Lao UI,Latha,Leelawadee,Leelawadee UI,Leelawadee UI Semilight,Levenim MT,LilyUPC,Lucida Console,Lucida Sans Unicode,Malgun Gothic,Mangal,Marlett,Meiryo,Meiryo UI,Microsoft Himalaya,Microsoft JhengHei,Microsoft JhengHei Light,Microsoft JhengHei UI,Microsoft JhengHei UI Light,Microsoft New Tai Lue,Microsoft PhagsPa,Microsot 0m 03.81s: Init burn engine successful.
    0m 06.23s: Init driveX with I/O mode: 0
    0m 06.23s: opening drive D
    0m 06.23s: opened i/o
    0m 06.24s: got media type 15
    0m 06.61s: got max lba 23770463
    0m 07.54s: got disc type 20
    0m 07.54s: type Blu-ray BDMV
    0m 07.54s: volume label DEFIANCES1D1_NA
    0m 07.57s: internal path D:/BDMV/
    0m 07.61s: aacs 1 bd+ 0
    0m 07.92s: got bdmv
    0m 07.94s: movie name: defiance season one (disc 1)||defiances1d1_na
    0m 07.94s: got agid 0
    0m 08.76s: sent host cert chal
    0m 08.76s: got drive cert chal
    0m 08.76s: BEC 1
    0m 08.76s: DRIVE_VENDOR 0x0080
    0m 10.09s: got drive key
    0m 10.09s: got host key signature
    0m 10.09s: verified drive signature
    0m 10.09s: verified host signature
    0m 11.52s: sent host signature and key point
    0m 11.52s: got bus key
    0m 11.53s: got volume id
    0m 11.53s: got volume id mac
    0m 11.53s: volume id is correct
    0m 11.54s: got vid
    0m 11.68s: blu-ray 64E48D9289B502C4EBB5FC456A8ED4C77D447624
    0m 12.21s: cert BEE=0x00 same
    0m 13.44s: got agid 0
    0m 14.27s: sent host cert chal
    0m 14.27s: got drive cert chal
    0m 14.27s: BEC 1
    0m 14.27s: DRIVE_VENDOR 0x0080
    0m 15.55s: got drive key
    0m 15.55s: got host key signature
    0m 15.55s: verified drive signature
    0m 15.55s: verified host signature
    0m 16.98s: sent host signature and key point
    0m 16.98s: got bus key
    0m 19.87s: D DECF7B68
    0m 19.88s: got vuk
    0m 19.92s: got unit key 1
    0m 26.09s: got bdmv
    0m 36.27s: got extended bdinfo
    0m 36.27s: opened blu-ray
    0m 37.45s: terminate process
