dvdfab: freezing computer/only copy 1
    yo guys and gals....
    have version 6.2.1.6 . problem is, can only copy 1 disc then it freezes.
    not only the program, but computer. have to reboot after each copy.
    new computer with tons of disc and ram space.quad core. thinking a
    conflict somewhere, but can't find it. lg cd/dvd burner. all items are checked
    in the general area except delete files when done. gpu acceleration is
    enabled. started with 6.? and have updated with each new release but the
    problem has been from the get-go. any guru's with a solution. thx.....
    try disabling the GPU acceleration
      not gpu.still looking for an answer
      okay..tried that to no avail. still copy only once and all freezes. have to
      manually reboot. did notice this time...pause...was highlighted after copy
      and spitting out the dvd. just seems like it doesn't finish a cycle.can't end with task manager or anything. still looking for an answer.
        still freezing up
        have 6.2 and looked over system,settings, and security. maybe copy 1
        movie, but doesn't finish, and then freezes up everything. have to reset
        to get anything to go. just can't figure this out. Anybody?
          Where in the process does the computer freeze encoding or burning? How is the cooling on your computer? Have you monitored it?
