Cannot open drive
    Cannot open drive
    Hi
    Recently dvdfab 8.QT started telling me it cannot open my drive. So I did a drag & drop Then I upgraded. Now I am using 9.0.7.2 and it says it is not playable what is happening?
    Help please
    Qman7112
    DVDFab 9.0.7.2 (2013/11/12 11:52:43)
    0m 00.35s: Start preload dll...
    0m 00.43s: Load dll successful.
    0m 00.43s: Start load fabplay dll...
    0m 00.54s: Load fabplay dll successful.
    0m 00.54s: Transfer settings successful.
    0m 00.54s: info: fabcheck logpath= C:\Users\Qmans\Documents\DVDFab\Log\
    0m 00.56s: fab_check_gpu is running ...
    0m 01.15s: fab_check_gpu run successful
    0m 01.17s: info: recommand= 0, Shrink= 0, cuda_cap= 0 , cpu_count= 2
    0m 01.17s: GPUAccelerate: 4
    0m 01.17s: CUDA cap: 0
    0m 01.17s: Support coreavc decode: 0
    0m 01.17s: Graphics info: Mobile Intel(R) 4 Series Express Chipset Family : :
    0m 01.17s: Load config successful.
    0m 01.18s: Windows os type is: 13.
    0m 01.37s: Parse string is: 2:1446854842
    0m 01.37s: Parse string is: 1:0
    0m 01.37s: Parse string is: OV:9072
    0m 01.37s: Parse string is: BV:9102
    0m 01.38s: Option check status: Local
    0m 01.38s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
    0m 01.40s: Start get sys number.
    0m 01.40s: Init GPU settings successful.
    0m 01.40s: CommmandLine:
    0m 02.29s: Serial number is: 06-23-4e-35-55-00:00-23-4e-35-55-00:00-1f-16-5d-2e-b8
    0m 02.29s: Reg URL link is:
    0m 02.29s: Version is: 9072
    0m 02.29s: Product is: 2
    0m 02.29s: Connect type is: 0
    0m 02.46s: Begin init preview play engine.
    0m 02.48s: Init DirectShow engine successful.
    0m 02.79s: locale: en_US
    lan: ENU
    default font: ms shell dlg
    use font: Arial
    fonts: Academy Engraved LET,Adobe Caslon Pro,Adobe Caslon Pro Bold,Adobe Garamond Pro,Adobe Garamond Pro Bold,Aharoni,Andalus,Angsana New,AngsanaUPC,Aparajita,AR BERKLEY,AR BLANCA,AR BONNIE,AR CARTER,AR CENA,AR CHRISTY,AR DARLING,AR DECODE,AR DELANEY,AR DESTINE,AR ESSENCE,AR HERMANN,AR JULIAN,Arabic Typesetting,Arial,Arial Black,Arial Narrow,Arial Unicode MS,Arno Pro,Arno Pro Caption,Arno Pro Display,Arno Pro Light Display,Arno Pro Smbd,Arno Pro Smbd Caption,Arno Pro Smbd Display,Arno Pro Smbd SmText,Arno Pro Smbd Subhead,Arno Pro SmText,Arno Pro Subhead,Batang,BatangChe,Bell Gothic Std Black,Bell Gothic Std Light,Bickham Script Pro Regular,Bickham Script Pro Semibold,Birch Std,Blackletter686 BT,Blackoak Std,Book Antiqua,Bookman Old Style,Bookshelf Symbol 7,Bradley Hand ITC,Broadway BT,Browallia New,BrowalliaUPC,Brush Script Std,Calibri,Calibri Light,Calligraph421 BT,Cambria,Cambria Math,Candara,Cataneo BT,Century,Century Gothic,Cha! 0m 03.96s: Profile Manager :: End Load Profile
    0m 04.10s: Times of connecting error is: 0
    0m 04.10s: Parse string is: 2:1446854842
    0m 04.10s: Parse string is: 1:0
    0m 04.10s: Parse string is: OV:9072
    0m 04.10s: Parse string is: BV:9102
    0m 04.10s: Option check status: NewWork
    0m 04.10s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
    0m 11.29s: Init burn engine successful.
    0m 14.22s: Init driveX with I/O mode: 0
    0m 14.26s: opening drive E
    0m 14.32s: opened i/o
    0m 14.32s: got media type 5
    0m 14.33s: got max lba 0
    0m 14.67s: opening drive G
    0m 14.67s: opened i/o
    0m 21.87s: set folder K:/videos/VIDEO_TS/ with type 0
    0m 21.87s: opening folder K:/videos/VIDEO_TS/
    0m 22.26s: set folder K:/videos/VIDEO_TS/ with type 0
    0m 22.26s: opening folder K:/videos/VIDEO_TS/
    0m 22.28s: failed to open 0
    my OS W8
    Dunno!!! How about some logs?
      Cannot open drive
      Sorry got interrupted
      Here is another log
      DVDFab 8.2.2.2 (2013/11/12 11:47:48)
      0m 03.68s: GPUAccelerate: 4
      0m 03.68s: CUDA cap: 0
      0m 03.68s: Support coreavc decode: 0
      0m 03.68s: Graphics info: Mobile Intel(R) 4 Series Express Chipset Family : :
      0m 03.74s: Qt Translator file load success
      0m 04.65s: Load config successful.
      0m 04.68s: Init profile data driver sucessful.
      0m 13.23s: Init GPU settings sucessful.
      0m 13.23s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 0 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
      0m 13.24s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
      0m 13.96s: Config ExBar successful.
      0m 13.96s: dvd2dvd have 8 elements.
      0m 14.24s: dvd2mobile have 30 elements.
      0m 15.96s: blu-ray2blu-ray have 4 elements.
      0m 16.07s: blu-ray2mobile have 21 elements.
      0m 17.22s: blu-ray23d have 7 elements.
      0m 17.57s: blu-ray2dvd have 1 elements.
      0m 17.61s: file2mobile have 31 elements.
      0m 19.45s: file2dvd have 1 elements.
      0m 19.55s: file2bluray have 1 elements.
      0m 20.42s: Config work ui controls successful.
      0m 20.76s: Init burn engine successful.
      0m 20.89s: StartNotify successful.
      0m 20.94s: opening drive E
      0m 20.96s: opened i/o
      0m 20.96s: got media type 5
      0m 20.97s: got disc type 0
      0m 20.97s: got max lba 0
      1m 12.31s: opening folder K:/videos/FullDisc/FullDisc/MainMovie/MAN_OF_STEEL/VIDEO_TS/
      1m 12.40s: failed to open 0
      1m 21.53s: opening folder K:/videos/FullDisc/FullDisc/MainMovie/MAN_OF_STEEL/VIDEO_TS/
      1m 21.57s: failed to open 0
        Try opening the folder ABOVE the VIDEO_TS folder.
