This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
What am I doing wrong? Using DVD ripper my output is MP4. While playing back the movie the audio and video seem to get out of sync the further into the movie. This has happened in version 8 as well as 9.
Please help.
I upgraded and disabled all GPU codecs.
The sync seems to be better, but now I don't have any subtitles. I am also trying to extract to idx/sub file.
Any suggestions?
DVDFab 9.1.0.6 (2013/11/20 19:01:42)
0m 01.06s: Start preload dll...
0m 01.12s: Load dll successful.
0m 01.13s: Start load fabplay dll...
0m 01.23s: Load fabplay dll successful.
0m 04.14s: Transfer settings successful.
0m 04.14s: info: fabcheck logpath= C:\Users\Dan\Documents\DVDFab9\Log\
0m 04.19s: fab_check_gpu is running ...
0m 04.38s: fab_check_gpu run successful
0m 04.41s: info: recommand= 0, Shrink support= 0, enable= 0, cuda_cap= 0 , cpu_count= 4
0m 04.41s: GPUAccelerate: 7
0m 04.41s: GPUAccelerate setting: 0, 0
0m 04.41s: CUDA cap: 0
0m 04.43s: Support coreavc decode: 0
0m 04.43s: Lighting shrink status: 0, 0
0m 04.43s: Graphics info: AMD Radeon(TM) HD 6620G : :
0m 04.44s: Load config successful.
0m 04.44s: Windows os type is: 13.
0m 04.75s: Profile Manager :: End Load Profile
0m 04.83s: Parse string is: 2:1327947336
0m 04.86s: Parse string is: 11:8260762964
0m 04.86s: Parse string is: 50:14
0m 04.86s: Parse string is: OV:9106
0m 04.86s: Parse string is: BV:9102
0m 04.86s: Parse string is: S:37eb16da321b5fa5ea3896c01ce63ac7
0m 04.86s: Option check status: Local
0m 04.97s: HD Decrypter-1-0-215811
0m 04.97s: DVD to DVD (Gold)-0-0-200011
0m 04.97s: DVD to DVD-0-1-2012131
0m 04.97s: DVD to Mobile-1-1-22311011
0m 04.97s: Blu-ray to Blu-ray-0-0-200011
0m 04.97s: Blu-ray to Mobile-0-0-200011
0m 04.97s: File to Mobile-1-0-2013123
0m 04.99s: Blu-ray to DVD-0-0-200011
0m 04.99s: File to DVD-0-0-200011
0m 04.99s: File to Blu-ray-0-0-200011
0m 04.99s: File Mover-1-0-215811
0m 04.99s: Blu-ray to 3D-0-0-200011
0m 04.99s: 2D to 3D-0-0-200011
0m 04.99s: Blu-ray Decrypt-1-0-200011
0m 04.99s: DVD Decrypt-1-0-200011
0m 04.99s: Start get sys number.
0m 04.99s: Get advertising info start
0m 04.99s: Product type is: 2
0m 04.99s: Advertising id: 1
0m 04.99s: URL link is:
0m 04.99s: Language type is: ENU
0m 04.99s: Serial number is: 60-d8-19-97-6d-1c:60-d8-19-97-6d-1d:2c-41-38-5a-7b-61
0m 04.99s: Reg URL link is:
0m 04.99s: Version is: 9106
0m 04.99s: Product is: 2
0m 04.99s: Connect type is: 0
0m 05.00s: error curl post: Couldn't resolve host name
0m 05.02s: error curl post: Couldn't resolve host name
0m 05.02s: Connect test Failed.
0m 05.02s: Times of connecting error is: 2
0m 05.02s: Get registration info failed, the return string is:
0m 05.13s: Init GPU settings successful.
0m 05.13s: CommmandLine:
0m 06.53s: Begin init preview play engine.
0m 06.55s: Init DirectShow engine successful.
0m 12.32s: Init burn engine successful.
0m 13.07s: Init setting page successful.
0m 20.35s: Init driveX with I/O mode: 0
0m 20.55s: opening drive E
0m 20.60s: opened i/o
2m 35.74s: opening drive E
2m 36.54s: opened i/o
2m 36.54s: got media type 4
2m 37.06s: got max lba 4061969
2m 37.06s: got disc type 10
2m 37.12s: type DVD-VIDEO
2m 37.12s: volume label OBLIVION
2m 37.16s: internal path E:/VIDEO_TS/
2m 37.18s: got copyright 1 fe
2m 38.01s: got udf/iso
2m 41.32s: got discinfo
2m 41.34s: pathplayer enabled
2m 46.31s: button: vts_5 menu_1 pgc_17 cell_2 sector_23547 count_4
3m 05.54s: button: vts_5 menu_1 pgc_14 cell_1 sector_240 count_6
3m 05.61s: button: vts_5 menu_1 pgc_19 cell_1 sector_1114 count_6
3m 16.46s: button: vts_5 menu_1 pgc_22 cell_1 sector_21823 count_4
3m 16.94s: button: vts_5 menu_1 pgc_18 cell_1 sector_1372 count_4
3m 17.16s: button: vts_5 menu_1 pgc_6 cell_1 sector_0 count_12
3m 20.10s: button: vts_5 menu_1 pgc_6 cell_2 sector_40 count_12
3m 20.35s: button: vts_5 menu_1 pgc_6 cell_3 sector_82 count_12
3m 20.57s: button: vts_5 menu_1 pgc_6 cell_4 sector_125 count_12
3m 20.83s: button: vts_5 menu_1 pgc_6 cell_5 sector_165 count_12
3m 21.08s: button: vts_5 menu_1 pgc_7 cell_1 sector_21721 count_7
3m 21.31s: button: vts_5 menu_1 pgc_21 cell_1 sector_21663 count_6
4m 18.04s: got dvdinfo
4m 18.04s: opened dvd
4m 31.06s: Work Profile : MP4.Default
4m 35.68s: Work Profile : MP4.Default
11m 24.98s: Start check DVD Ripper register status.
11m 24.99s: End check DVD Ripper register status: Enable
11m 25.02s: OPList at DVD Ripper : (480.2),(128.2),(32.16)
11m 25.03s: DVD ripper check watermark flag: 0
11m 29.63s: ------------------ convert work begin(1/1) ------------------
11m 29.63s: info: create config(dvd2video)
11m 29.64s: info: use profile(MP4.Default)
11m 29.64s: info: dvd playlist(5),angle(0),chapter(1->21)
11m 29.64s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
11m 30.22s: info: stream input@ Video(480)[codec(mpeg2video) size(720*480) fps(24000/1001) interlace(0) opcode(compress)]
11m 30.25s: info: perset file config OK !
11m 30.25s: info: set output video frame_rate(24000/1001)
11m 30.27s: info: stream output Video(480)[codec(h264) size(720*304) fps(24000/1001) interlace(0)]
11m 30.29s: info: stream input@ Audio(128)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(16) opcode(compress)]
11m 30.32s: info: stream output Audio(128)[codec(aac) channels(6) sample(48000) bitrate(448000) bitdepth(16)]
11m 30.32s: info: stream input@ SubPicture(32)[codec(dvdsub) language(English) opcode(extract)]
11m 30.33s: info: stream output SubPicture(32)[codec(xsub) language(English)]
11m 30.33s: info: SubMode(Extract) -- Display Only forced Subtitle(true)
11m 31.57s: info: h264_encode: encode param profile(1) level(30) bitrate(788) crf(-1)
31m 29.06s: Init driveX with I/O mode: 0
31m 29.07s: opening drive F
31m 29.08s: opened i/o
31m 29.08s: failed to get max lba: sensekey 02 asc 3A acsq 00
31m 48.99s: Init driveX with I/O mode: 0
31m 49.01s: opening drive F
31m 49.01s: opened i/o
31m 49.01s: failed to get max lba: sensekey 02 asc 3A acsq 00
33m 08.05s: Init driveX with I/O mode: 0
33m 08.06s: opening drive F
33m 08.56s: opened i/o
33m 08.56s: failed to get max lba: sensekey 02 asc 3A acsq 00
33m 32.79s: Init driveX with I/O mode: 0
33m 32.79s: opening drive F
33m 32.80s: opened i/o
33m 32.80s: failed to get max lba: sensekey 02 asc 3A acsq 00
37m 30.96s: Init driveX with I/O mode: 0
37m 30.97s: opening drive F
37m 30.98s: opened i/o
37m 30.98s: failed to get max lba: sensekey 02 asc 3A acsq 00
56m 25.99s: info: audio_decode finish job
56m 34.11s: audio_encode finish job
56m 42.04s: ------------------ convert work finished ------------------
