Eject bluray when Finished
    I can't find that option in .6 of DVDFab 9. I've looked and looked.
    Is it there and if so where is the option for DVDFab 9 to eject the bluray when finished?
    If not there can it be added?
    Eject disk you can turn it off here.
      My selection is not checked but the bluray disk still does not eject when finished.
      DVD's yes. Blurays no.
        Re download Fab maybe corrupt file in your version mine always ejects.Note the check box has to be unchecked for both dvds and blu rays so they both eject.This happens after you copy a disk or do a burn.
          Have both V8 and V9 and in both the box is not selected. DVD's eject, blurays do not.
          Just installed official release this morning.
          Have 2 drives, bluray and a dvd drive. From what I can tell DVDFab sends the eject command to only one of the drives. It needs to do so to all listed/used drives.
            Are both your drives checked in Fab settings see screen shot.
              Have both drives checked and tried it with just bluray drive checked.
              No change in behaviors.
              Bluray finished, drive does not eject the disk.
                Is you firmware on the blu ray drive up to date? Doe's your drive door stick?
                I really can't think of anything else.Mine works fine.
                  Uncheck "Does not eject source after finished copying" option in Common Setting -> Drivers -> Read.
                    Which selection?
                    Before to ask support:
                    http://forum.dvdfab.cn/showthread.php?t=16
                    Avant de demander du support:
                    http://forum.dvdfab.cn/showthread.php?t=10981
                      When I make an iso the disk ejects when finished.
                      Any other output options the disk does not.
                      So it is possible....
                        "Which selection?"
                        The "Do not eject..." options.
                        I need to test it with the suggestion about source eject....
                        Right now dealing with the dang frustration of jerky mkv's with latest version. Have to check today's release 1.1.0.....
                        Very annoying when MKV output used to work but goes back to having issues. Who is NOT paying attention DVDFAB?!?
                          Is already unchecked. For both DVD and Bluray options in "Read" area.
                          Bluray drive firmware is up to date.
                          As noted it works as intended when doing ISO's. So code that works and the proper response from the bluray drive is in place, just for iso files.
