Selected sound format
    One thing I never understood in DVDFab Copy and this has been true for as long as I can recall is when there are two audio formats to choose from (AC-3/5.1 and DTS/5.1) and I only select one of these why will still both formats be copied which makes the copy process take much longer than needed?
    If you uncheck the green check mark in (main movie) the audio you don't want then it will only record the soundtrack in the checked box.
      That is exactly what I do but more often than not also the sound format I unchecked is included.
        Are you moving the black delta (arrow head) symbol too? That selects the default audio track and may cause track to copy even if unchecked, haven't checked this out?
          I don't have the program in front of me right now but I'll check that out next time, thanks for the tip!
            Don't waste your time I just checked and the indicator moves when the track is unchecked so it's not possible.
              Ok
                If your using the version 9111 version of Fab it works as i told you I tested it 3 times with different movies.
                  I'm using the latest beta version but this doesn't seem to be dependent on the version because I've seen in long time back.
                  Will do more testing and see if I can find out what is causing it.
