Problems with 3D Blu-Ray
    I have a problem ripping my 3D Iron Man 3. It always stops after abotu 20%. Nothing more happens after this. Same with another 3D movie. Any idea, what´s going wrong? Thanks for your help?
    Regards
    ladymel
    Attached the log:
    DVDFab 9.1.1.5 (2013/12/15 14:45:30)
    0m 00.09s: Transfer settings successful.
    0m 00.10s: warning: FabPlay: invalid gpu detect handle
    0m 00.10s: GPUAccelerate: 0
    0m 00.10s: GPUAccelerate setting: 0, 0
    0m 00.10s: CUDA cap: 0
    0m 00.10s: Support coreavc decode: 0
    0m 00.10s: Lighting shrink status: 0, 0
    0m 00.10s: Graphics info: : :
    0m 00.11s: Load config successful.
    0m 00.11s: Windows os type is: 13.
    0m 01.81s: Profile Manager :: End Load Profile
    DVDFab 9.1.1.5 (2013/12/15 14:45:41)
    0m 00.12s: Start preload dll...
    0m 00.17s: Load dll successful.
    0m 00.17s: Start load fabplay dll...
    0m 00.25s: Load fabplay dll successful.
    0m 00.25s: Transfer settings successful.
    0m 00.26s: info: fabcheck logpath= C:/Users/Wolfgang/Documents/DVDFab9/Log/
    0m 00.27s: fab_check_gpu is running ...
    0m 00.38s: fab_check_gpu run successful
    0m 00.38s: info: recommand= 0, Shrink support= 0, enable= 0, cuda_cap= 0 , cpu_count= 4
    0m 00.38s: GPUAccelerate: 3
    0m 00.38s: GPUAccelerate setting: 0, 0
    0m 00.38s: CUDA cap: 0
    0m 00.39s: Support coreavc decode: 0
    0m 00.39s: Lighting shrink status: 0, 0
    0m 00.39s: Graphics info: ATI Radeon HD 4670 : :
    0m 00.40s: Load config successful.
    0m 00.40s: Windows os type is: 13.
    0m 00.47s: Option check status: Failed
    0m 00.48s: HD Decrypter-1-0-215811
    0m 00.48s: DVD to DVD (Gold)-0-0-200011
    0m 00.48s: DVD to DVD-0-0-200011
    0m 00.48s: DVD to Mobile-0-0-200011
    0m 00.48s: Blu-ray to Blu-ray-0-0-200011
    0m 00.48s: Blu-ray to Mobile-0-0-200011
    0m 00.48s: File to Mobile-0-0-200011
    0m 00.48s: Blu-ray to DVD-0-0-200011
    0m 00.49s: File to DVD-0-0-200011
    0m 00.49s: File to Blu-ray-0-0-200011
    0m 00.49s: File Mover-1-0-215811
    0m 00.49s: Blu-ray to 3D-0-0-200011
    0m 00.49s: 2D to 3D-0-0-200011
    0m 00.49s: Blu-ray Decrypt-1-0-200011
    0m 00.49s: DVD Decrypt-1-0-200011
    0m 00.50s: Start get sys number.
    0m 00.50s: Serial number is: 00-24-1d-d9-fb-88
    0m 00.50s: Reg URL link is:
    0m 00.50s: Version is: 9115
    0m 00.50s: Product is: 2
    0m 00.51s: Connect type is: 1
    0m 01.66s: Times of connecting error is: 0
    0m 01.66s: Parse string is: 70:29
    0m 01.67s: Parse string is: OV:9115
    0m 01.67s: Parse string is: BV:9116
    0m 01.96s: Profile Manager :: End Load Profile
    0m 02.01s: Option check status: NewWork
    0m 02.01s: HD Decrypter-1-0-215811
    0m 02.01s: DVD to DVD (Gold)-1-0-215811
    0m 02.01s: DVD to DVD-1-0-215811
    0m 02.01s: DVD to Mobile-1-0-215811
    0m 02.01s: Blu-ray to Blu-ray-1-0-215811
    0m 02.02s: Blu-ray to Mobile-1-0-215811
    0m 02.02s: File to Mobile-1-0-215811
    0m 02.02s: Blu-ray to DVD-1-0-215811
    0m 02.02s: File to DVD-1-0-215811
    0m 02.02s: File to Blu-ray-1-0-215811
    0m 02.02s: File Mover-1-0-215811
    0m 02.02s: Blu-ray to 3D-1-0-215811
    0m 02.03s: 2D to 3D-1-0-2014113
    0m 02.03s: Blu-ray Decrypt-1-0-200011
    0m 02.03s: DVD Decrypt-1-0-200011
    0m 02.03s: End check info.
    0m 02.03s: connect 0 : start.
    0m 02.04s: Init GPU settings successful.
    0m 02.04s: CommmandLine:
    0m 02.65s: Begin init preview play engine.
    0m 02.69s: Init DirectShow engine successful.
    0m 02.98s: Burn engine: start init.
    0m 03.11s: Burn engine: type-0.
    0m 03.12s: Burn engine: 0- E:\ [TSSTcorp DVDWBD SH-B123L SB04 (Ide)].
    0m 03.12s: Burn engine: 1- F:\ [Optiarc DVD RW AD-7240S 1.02 (Ide)].
    0m 03.12s: Burn engine: end init.
    0m 03.59s: Init setting page successful.
    0m 20.51s: connect 0 : 1:1-10:1-11:1-12:1-13:1-14:1-15:1-
    0m 22.26s: Start get sys number.
    0m 22.27s: Serial number is: 00-24-1d-d9-fb-88
    0m 22.28s: Reg URL link is:
    0m 22.28s: Version is: 9115
    0m 22.29s: Product is: 2
    0m 22.29s: Connect type is: 0
    0m 23.29s: Times of connecting error is: 0
    0m 23.30s: Parse string is: 21:8260762964
    0m 23.30s: Parse string is: 22:8260762964
    0m 23.31s: Parse string is: 70:29
    0m 23.32s: Parse string is: OV:9115
    0m 23.32s: Parse string is: BV:9116
    0m 23.33s: Parse string is: S:99088847866b6bd2537a6cd737c8918e
    0m 23.80s: Option check status: NewWork
    0m 23.80s: HD Decrypter-1-0-215811
    0m 23.81s: DVD to DVD (Gold)-1-0-215811
    0m 23.81s: DVD to DVD-1-0-215811
    0m 23.82s: DVD to Mobile-1-0-215811
    0m 23.82s: Blu-ray to Blu-ray-1-0-215811
    0m 23.82s: Blu-ray to Mobile-1-1-22311011
    0m 23.83s: File to Mobile-1-0-215811
    0m 23.83s: Blu-ray to DVD-1-0-215811
    0m 23.83s: File to DVD-1-0-215811
    0m 23.83s: File to Blu-ray-1-0-215811
    0m 23.84s: File Mover-1-0-215811
    0m 23.84s: Blu-ray to 3D-1-1-22311011
    0m 23.84s: 2D to 3D-1-0-2014113
    0m 23.84s: Blu-ray Decrypt-1-0-200011
    0m 23.85s: DVD Decrypt-1-0-200011
    0m 30.71s: Init driveX with I/O mode: 0
    0m 30.72s: Init driveX with I/O mode: 0
    0m 30.72s: opening drive E
    0m 30.72s: opened i/o
    0m 30.73s: got media type 15
    0m 33.37s: got max lba 24209791
    0m 36.20s: got disc type 20
    0m 36.20s: type Blu-ray BDMV
    0m 36.21s: volume label IRON MAN 3 3D
    0m 36.23s: opening drive E
    0m 36.24s: opened i/o
    0m 36.24s: got media type 15
    0m 36.92s: got max lba 24209791
    0m 37.81s: got disc type 20
    0m 37.82s: type Blu-ray BDMV
    0m 37.83s: volume label IRON MAN 3 3D
    0m 37.83s: opening drive F
    0m 37.85s: opened i/o
    0m 39.48s: Open blu-ray disc expired time: 22311011
    0m 39.48s: internal path E:/BDMV/
    0m 39.52s: aacs 1 bd+ 0
    0m 45.82s: got bdmv
    0m 46.15s: movie name: iron man 3||iron man 3 3d
    0m 46.16s: got agid 0
    0m 46.23s: sent host cert chal
    0m 46.23s: got drive cert chal
    0m 46.24s: BEC 1
    0m 46.25s: DRIVE_VENDOR 0x0182
    0m 46.33s: got drive key
    0m 46.33s: got host key signature
    0m 46.34s: verified drive signature
    0m 46.35s: verified host signature
    0m 46.43s: sent host signature and key point
    0m 46.44s: got bus key
    0m 47.75s: got volume id
    0m 47.76s: got volume id mac
    0m 47.77s: volume id is correct
    0m 47.78s: got vid
    0m 48.68s: blu-ray 52ADCE371F8AEEE4AE7B34FCEE1C37CB2110D19D
    0m 49.24s: cert BEE=0x00 same
    0m 51.14s: D 828A6D82
    0m 51.18s: main playlist 00000.mpls
    0m 51.19s: selected region B
    0m 51.19s: got vuk
    0m 51.58s: got unit key 1
    1m 06.88s: got bdmv
    1m 17.07s: got extended bdinfo
    1m 17.07s: opened blu-ray
    2m 35.34s: ========WorkAttr::SetSource=======
    2m 35.34s: Source Video Size Original : 1920 x 800
    2m 35.34s: Source Video Size Display : 1920 x 800
    2m 35.35s: Source Video FPS : 24000 / 1001
    2m 35.35s: Source Video Bitrate : 1200
    2m 35.35s: Source Audio Bitrate : 0
    2m 35.35s: Source Audio Channels : 8
    2m 35.35s: Source Audio Volume : 100
    2m 35.36s: Work Profile : MP4
    2m 46.98s: ========WorkAttr::SetSource=======
    2m 46.98s: Source Video Size Original : 1920 x 800
    2m 46.99s: Source Video Size Display : 1920 x 800
    2m 46.99s: Source Video FPS : 24000 / 1001
    2m 46.99s: Source Video Bitrate : 1200
    2m 46.99s: Source Audio Bitrate : 0
    2m 46.99s: Source Audio Channels : 8
    2m 46.99s: Source Audio Volume : 100
    2m 47.00s: Work Profile : 3D MKV
    3m 21.23s: UILog:OnMsgToolbar_Start
    3m 21.25s: UILog:Msg Start : ready start
    3m 21.26s: UILog:Msg Start : start test run work
    3m 21.28s: UILog:right button to null, work falg = -1
    3m 21.29s: UILog:Msg Start : run work
    3m 21.29s: UILog:Run current Work.
    3m 21.58s: UILog:Begin work ripper.
    3m 21.59s: UILog:Begin work copy or converter.
    3m 21.60s: Start check Blu-ray Ripper (3D Plus) register status.
    3m 21.61s: End check Blu-ray Ripper (3D Plus) register status: Enable
    3m 21.62s: UILog:start running at thread.
    3m 21.63s: UILog:return flag at start running at thread ok.
    3m 21.77s: OPList at BD Ripper : (4113.2),(4352.2),(4608.32)
    3m 21.78s: Blu-ray ripper (3D Plus) check watermark flag: 0
    3m 21.78s: ------------------ convert work begin(1/1) ------------------
    3m 21.78s: info: create config(bluray2video)
    3m 21.79s: info: use profile(3D MKV)
    3m 21.79s: info: bluray playlist(0),angle(0),chapter(1->17),BDAV(no)
    3m 21.79s: info: 3D working_mode(bluray_3D), 3D format(sbs_lef_right)
    3m 21.81s: info: stream input@ Video(4113)[codec(h264) size(1920*1080) fps(24000/1001) interlace(0) opcode(compress)]
    3m 21.82s: info: perset file config OK !
    3m 21.82s: info: set output video frame_rate(24000/1001)
    3m 21.82s: info: stream output Video(4113)[codec(h264) size(1920*800) fps(24000/1001) interlace(0)]
    3m 21.82s: info: stream input@ Audio(4352)[codec(dca) channels(8) sample(48000) bitrate(0) bitdepth(16) opcode(compress)]
    3m 21.83s: info: stream output Audio(4352)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(16)]
    3m 21.83s: info: stream input@ SubPicture(4608)[codec(pgssub) language(German) opcode(remux)]
    3m 21.84s: info: stream output SubPicture(4608)[codec(pgssub) language(German)]
    3m 21.84s: info: SubMode(Remux) -- Display Only forced Subtitle(false)
    3m 21.85s: UILog:MsgWork:WorkStatus_Start
    3m 22.89s: info: h264_encode: encode param profile(2) level(41) bitrate(14068) crf(-1)
    3m 26.99s: info: processing source(00000.ssif)
    does anybody have an idea? It is not only 3D, no BluRay can be ripped with the latest version (it´s a bought version). To make a copy with the testversion is not a problem at all.
    Do you need more information? Attached you can see a screenshot from DVDFab.
    Thanks and regards
    ladymel
      New!DVDFab 9.1.1.7 Beta is out
      New!DVDFab 9.1.1.7 Beta is out (December 16, 2013)
      Fix: A freeze problem when ripping or copying Blu-ray 3D discs, this problem is introduced in 9116 Beta.
      Try the new Fab if same problem post new logs please.I have a problem with cars 3d also doing the same thing even with 9117 so lets see if your problem is the same as mine.What do you mean the test version works do you mean the trial version? or what version of Fab works?
        Did you install the BitDefender on your PC? BitDefender does not like DVDFab when converting.
