You guys ROCK!!!!!!! Thank You!!!!!
    Other You guys ROCK!!!!!!! Thank You!!!!!
    THANK YOU!!!!! In 9.1.2.5 you guys fixed the display issue with my 2013 MacBook Pro with Retina Display running windows/Bootcamp.
    Under older versions, the dialog boxes were TINY TINY TINY and I couldn't see any of the text as it was too big inside thing like dropdown list boxes. Now you've fixed it and I can actually see everything!
    THANK YOU!!!!!
    Now if you could just fix the software so I can rip "Anchorman" to a Mp4 file and have the lip sync correct, I'd be forever in your debt :-)
    What device are you playing back the mp4 on stewie7669?
      Remember this is Mac...
        Yep, but he may be playing the mp4 on an iPad or something?
          Hi, stewie7669
          We are glad to know that your DPI problem has been solved.
          And about the lip sync problem, please post us the logs, thank you.
          I'm not a genius, but to make every effort to do it.
          Edison
            Originally posted by Edison View Post
            Hi, stewie7669
            I have at least twice.... I'll have to dig the Blu-ray out....
