Hi guys.
I have a Micca Media player that has a Gigabit Ethernet port and I am able to stream all of my DVD .iso, BluRay .iso, BluRay .mkv files to it.
It doesn't matter the size of the file... I can stream a 42GB BluRay image to it and not have any performance issues.
The issue with that device is... no Netflix.
That is fine for the Projector where I have this device hooked up to, but in our living room, I just ran a Gigabit connection (wire) and hooked up it to my WesternDig LiveTV and found out it only has a 10/100 Ethernet connection on it, and any .iso over 10GB in size... I can't stream well to it.
I'd just go get another Micca, but we use a lot of Netflix on that TV - so the Micca won't work for me there.
Any other suggestions on media boxes under $100 that have:
-Gigabit Ethernet
-Netflix App
-Ability to stream DVD & BluRay .iso and .mkv files.
Thanks guys.
-Gigabit Ethernet
-Netflix App
Thanks guys.
