I'm running low on space so I was wondering if my licensed DVD copy has a setting where I put in a DVD, run it through (stored in a temp folder) then put a blank disc in and id possible set Imgburn to do the burning. After burning is done delete the data in the temp folder. TIA!
How to get DVDFab Copy to burn also?
Yeah, DVDFab should should delete the temp files by default unless you've changed the setting.How to post the internal log
