HD Decrypter
    HD Decrypter
    Where do I find DVDFab HD Decrypter? I purchased DVDFab Blu-ray copy 9.1.2.5 just last week. When I start the program a license screen comes up first, telling me I have HD Decrypter lifetime and it's activated. When I click on this I am taken to DVDFab's web site to download 9.1.2.5 again.
    Is HD Decrypter not a stand alone program?
    Hi bluesnow
    I assume your using it for DVDs, you will not need it for Blu-Rays since you have the paid version.
    The free DVDFab HD Decrypter is bundled with the package, along with the other features, whether paid or trial, there is no single download for this.
    While using the free version you will not be able to compress or burn, you will have to use third party software to do this, and encryption updates are 30- 60 days behind the paid version.
    CBR929
      Thanks for the answer CBR929, but where do I find it?
        disconnect your computer from the internet and it'll revert to the free version.
          Or just select "copy" if the trial is over and the source is a DVD it will be HD decrypter.
            OK guys, thank you. I understand now.
